[GRASS-user] SRTM and r.fillnulls - using neighboring tiles
Hello all,
I’m trying to devise an efficient way to fill voids in SRTM, using neighboring tiles when there is edge nodata. In the end, I want to have tiles matching the input, just lacking any voids.
My initial thought is to write a simple gdal python script to determine which tiles have edge nodata and only process those. I’ll then write a script to:
  • determine which tiles are neighbors
  • merge those into a single temp dem
  • set the region to the desired tile
  • r.fillnull the temp file, creating an output with the correct extents
This should work, though I’m thinking there must be a more efficient way. Anyone have suggestions?
Thanks!
Jamie
