hi all,
there someone that can help me about srtm CGIAR data importing into grass 6.3?
Hi tryed by downloading data as GEOTIFF and I’ve imported in GRASS but the resultant map haven’t elevation, with ASCII GRID it happens the same
Thanks in advance
Regards
Edmondo
Edmondo,
Hi tryed by downloading data as GEOTIFF and I've imported in GRASS but the resultant map haven't elevation, with ASCII GRID it happens the same
Simply use r.in.gdal (please, note that you need to create a WGS84 location before to import the data in it).
Marco
Hi Edmondo,
The SRTM data and your location on grass are on the same coordinate system?
On Wed, Sep 24, 2008 at 9:48 AM, Edmondo Elisei <edmondo.elisei@gmail.com> wrote:
hi all,
Thanks in advance
Regards
Edmondo
grass-user mailing list
grass-user@lists.osgeo.org
Atenciosamente,
Raphael Saldanha
saldanha.plangeo@gmail.com
Fred Allen - “What’s on your mind, if you will allow the overstatement?”
