I have a SRTM DEM data from CGIAR (http://srtm.csi.cgiar.org/). I'm
trying to do local sea-level rise modelling.
Suppose I want it resampled to 30 meters with elevation at a
centimeters or millimeter units. Any thoughts on how to do this?
I believe the SRTM data are integer formats in meters. Converting
them to floating point does not necessaily enable you to do sub-meter
elevation calculations. Am I correct in my assumptions?
Thanks!
Maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |www.esambale.wikispaces.com|
| _)_/LI |www.geocities.com/esambale/philbiodivmap/philbirds.html |
On Fri, 23 Jun 2006 00:41:54 +0800
"maning sambale" <emmanuel.sambale@gmail.com> wrote:
Remember that the vertical accuracy of SRTM data does not permit you
to make considerations within such small range of altitude values,....
Carlos
> Hi,
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Note that there is SRTM Version 2 out - with improvements. AFAIK
SRTM DEM data from CGIAR is based on SRTM V1, but postprocessed.
Not sure if you gain anything because the vertical precision is 10m or so.
That's right. The information content doesn't change if you "just" change
the representation from integer to float. Additional information would be
needed to enrich the dataset.
