Hi!
How can I make a color table for a raster using standard deviation, like ArcGIS?
Raphael Saldanha
saldanha.plangeo@gmail.com
Hi!
Raphael Saldanha
On 11/08/08 16:59, Raphael Saldanha wrote:
Hi!
Try the Add-On script r.colors.stddev available from
http://grass.osgeo.org/wiki/GRASS_AddOns#r.colors.stddev
Moritz
Thank you!
I had downloaded the add-on… but how can I install it?
As I see on GRASS manual, I will need GEM, but where can I download this? Works in windows?
On Mon, Aug 11, 2008 at 12:36 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi!
Moritz
Atenciosamente,
Raphael Saldanha
Lucille Ball - “The secret of staying young is to live honestly, eat slowly, and lie about your age.”
On 12/08/08 13:28, Raphael Saldanha wrote:
Thank you!
I had downloaded the add-on... but how can I install it?
It's "just" a script, so no need for compilation or anything. Which OS are you using ?
If GNU/Linux, you can just download the script, make it executable with 'chmod +x r.colors.stddev' and then copy it somewhere into you path (or just execute it from the command line).
Moritz
On Mon, Aug 11, 2008 at 12:36 PM, Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
Hi!
deviation, like ArcGIS?Try the Add-On script r.colors.stddev available from
Moritz
Atenciosamente,Raphael Saldanha
saldanha.plangeo@gmail.com <mailto:saldanha.plangeo@gmail.com>
Lucille Ball - "The secret of staying young is to live honestly, eat slowly, and lie about your age."
Hi Moritz
I’m a newbie, using GRASS on Windows, version 6.3.0.
Thanks for you help!!!
On Tue, Aug 12, 2008 at 1:51 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Thank you!
It’s “just” a script, so no need for compilation or anything. Which OS are you using ?
If GNU/Linux, you can just download the script, make it executable with ‘chmod +x r.colors.stddev’ and then copy it somewhere into you path (or just execute it from the command line).
Moritz
On Mon, Aug 11, 2008 at 12:36 PM, Moritz Lennert <mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
Hi!
Moritz
saldanha.plangeo@gmail.com mailto:[saldanha.plangeo@gmail.com](mailto:saldanha.plangeo@gmail.com)
Atenciosamente,
Raphael Saldanha
