[GRASS-user] Start R w/in Cygwin and Native WinGrass?
I use window for my work computers so I have been using Grass under Cygwin and the latest native WinGrass and R for windows. By the way the WinGrass RC3 look GREAT!!!!
I want to use the R package spgrass6. Can/How do I start windows R within cygwin and WinGrass?
Thanks
Phil
Sent via BlackBerry by AT&T
<paallen <at> attglobal.net> writes:
Use a console interface - under cygwin I usually start an xterm within the GRASS
session, then start R within that (either Rgui or Rterm). You may need to set
.libPaths() within R, and may also need to check the working directory in Rgui,
depending on environment variable settings.
Roger
Thanks
Phil
grass-user mailing list
grass-user <at> lists.osgeo.org
paallen@attglobal.net wrote:
Thanks !
I have never tried this, but how I would: launch GRASS in text mode (either edit your .grassrc6 file and set GRASS_GUI to 'text' then click on your grass63.bat file, or launch cmd.exe and type 'c:\grass6rc3\bin\grass.bat -text' - adapt the path to wherever you dezipped grass). Then you have GRASS in command line mode and you should be able to launch R from there by typing 'R'. You might have to add the path of R's binaries and libraries to the PATH: 'set PATH=%PATH%;c:\R\bin;c:\R\lib' (again adapt according to your installation).
Tell us if it works.
Moritz
