I have installed 6.4.1svn and get the following startup error:
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
SEsMacPro:~ stu$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.6.1 found.
Cleaning up temporary files ...
Starting GRASS ...
ERROR: wxGUI requires wxPython. dlopen(/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so, 2): Symbol not found: __ZN10wxListCtrl19GetBackgroundColourEv
Referenced from: /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so
Expected in: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
in /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_controls_.so
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
I was using 6.4.0 immediately prior with the wxpython gui so it's there ........
The GRASS package seems to be incomplete - it's running the system wxpython, but linking the bundled wx libraries, which are probably much newer and incompatible with the system. If both wxpython and wx libraries are bundled, then maybe the bundled wxpython is not in the python path (it should be in etc/python in the GRASS app package).
Did you build from source? Or install a binary (I think Michael Barton has a svn binary available)?
On Oct 14, 2010, at 8:42 AM, Stuart Edwards wrote:
Hi -
OSX 10.6.4
Python 2.6.1 found.
Starting GRASS ...
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
Yes, from source.
Hi -
OSX 10.6.4
Python 2.6.1 found.
Starting GRASS ...
Yes, from source.
Are you using the system wxpython or did you install a binary from wxpython.org? (note: the system wxpython is a bit old, though it fits the minimum needed for GRASS)
Are you explicitly bundling wxpython? If not, it's odd that it thinks the wx libraries are bundled (the "expected in..." part of the error).
Hi -
OSX 10.6.4
Python 2.6.1 found.
Starting GRASS ...
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
On Oct 14, 2010, at 11:36 AM, William Kyngesburye wrote:
The GRASS package seems to be incomplete - it’s running the system wxpython, but linking the bundled wx libraries, which are probably much newer and incompatible with the system. If both wxpython and wx libraries are bundled, then maybe the bundled wxpython is not in the python path (it should be in etc/python in the GRASS app package).
Yes, from source.
It’s the system wxpython
Are you explicitly bundling wxpython? If not, it’s odd that it thinks the wx libraries are bundled (the “expected in…” part of the error).
No, I did the export nad2bin line and then configured with the given (long) ./configure (which doesn’t appear to mention python or wxpython…)
I did not do the '–with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-x.x.x.x/bin/wx-config modification
Hi -
OSX 10.6.4
ERROR: wxGUI requires wxPython. dlopen(/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/controls.so, 2): Symbol not found: __ZN10wxListCtrl19GetBackgroundColourEv
“We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty.”
“Don’t you even hate 'em?”
“What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn’t kill one ___ nor shorten the war one day.”
<Ha, ha> “And it might give 'em all stomach ulcers.”
... Oh! You say you used 6.4.0 before - was this my package? When you install 6.4.1 from source, it's installing on top of my 6.4.0. And probably leaving the bundled wx libraries already there, but removing the bundled wxpython, so when it tried to use the system wxpython it found the leftover bundled wx libraries.
Try deleting the old GRASS application before installing your GRASS compiled from source.
Yes, from source.
It's the system wxpython
No, I did the export nad2bin line and then configured with the given (long) ./configure (which doesn't appear to mention python or wxpython........)
I did not do the '--with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-x.x.x.x/bin/wx-config modification
Indeed
And quite a mess I made ; -(
Actually, I've had to download and reinstall your binaries just to get a working version going again - so I'm not inclined to risk losing my production setup. Can I give the current 6.4.0 a different name or does it have to be completely gone? I may well put this project on hold for a while.
BTW, thank you for maintaining such a fine repository of reliable binaries ......
Yes, from source.
You can rename the existing GRASS, say "GRASS-6.4.0.app".
Once you compile and install 6.4.1 (as GRASS-6.4.app), if you use Qgis it should continue to work using the new GRASS.
