[GRASS-user] startup error
Greetings!
Whenever I start up GRASS 6.4.2 using Fedora 18 I get the message:
Cleaning up temporary files ...
Starting GRASS ...
(python:10541): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion `GTK_IS_WIDGET (widget)' failed
and then the system starts running. Is this something I need to fix? If so, how should I proceed?
tia,
David Adam
On Wed, Jun 5, 2013 at 8:21 PM, david adam <david@quercus.org> wrote:
Greetings!
Cleaning up temporary files …
Starting GRASS …
(python:10541): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion `GTK_IS_WIDGET (widget)’ failed
these messages are usually harmless. If you don’t have other problems, just ignore it.
Anna
tia,
David Adam
grass-user mailing list
grass-user@lists.osgeo.org
david wrote:
Greetings!
message:
Starting GRASS ...
(widget)' failed
(widget)' failed
I don't know, but it seems to be a Fedora 18 GTK thing,
  https://bugzilla.redhat.com/show_bug.cgi?id=924683
(rather small world sometimes :slight_smile:
Hamish
