[GRASS-user] Statistics for each area of a thematic map
Hello all,
I’ve created a vector thematic map with a dozen of different areas (different units in a viticultural zoning study).
For the same region, I’ve got a few rasters as well: DEM, slope and aspect, annual precipitations, solar radiation, Winkler’s index, …
What I need is an estimate of some statistics as min, max, mean values of each variable (elevation, …) for each particular region. What do you suggest as the best method (for what concern speed and, above all, quality of results) in order to accomplish this task?
I only can imagine this:
  1. transform the vector map in raster
  2. use r.statistics (as in the example in the manual) or maybe r.statistics applied to the rasters of climatic variables after masking for each particular area.
Is there some better way, in particular a way which doesn’t involve transforming the vector map to raster?
Thanks in advance.
Odoardo Zecca
Institut Agricole Régional
Regione La Rochère 1/A
11100 Aosta
email: o.zecca@iaraosta.it
Odoardo Zecca napisał(a):
Hello all,
I've created a vector thematic map with a dozen of different areas (different units in a viticultural zoning study).
For the same region, I've got a few rasters as well: DEM, slope and aspect, annual precipitations, solar radiation, Winkler's index, ....
What I need is an estimate of some statistics as min, max, mean values of each variable (elevation, ...) for each particular region. What do you suggest as the best method (for what concern speed and, above all, quality of results) in order to accomplish this task?
1) transform the vector map in raster
2) use r.statistics (as in the example in the manual) or maybe r.statistics applied to the rasters of climatic variables after masking for each particular area.
Is there some better way, in particular a way which doesn't involve transforming the vector map to raster?
Thanks in advance.
Odoardo Zecca
11100 Aosta
email: o.zecca@iaraosta.it <mailto:o.zecca@iaraosta.it>
grassuser mailing list
grassuser@grass.itc.it
what about v.rast.stats?
Jarek
v.rast.stats seems to be what I was looking for.
Thank you Jaroslaw.
Odoardo Zecca
Hello all,
Thanks in advance.
Odoardo Zecca
11100 Aosta
email: o.zecca@iaraosta.it mailto:[o.zecca@iaraosta.it](mailto:o.zecca@iaraosta.it)
Jarek
