I need to calculate some statistics(min, max and median) for a raster along some line geometries.
The way I am using v.rast.stats is not calculating statistics for all line geometries. (Each line geometry is a straight line, but some of the line geometries are
nearby and some of them intersect.)
Is there a different command I can use to get these stats for all lines, or is there some other workaround ( maybe recursively create maps for lines for which the stats are not calculated)? I am hoping that someone has run into this problem before.
(I think the problem is that multiple lines may be passing through the same raster cell and only one line is picked, but I am not sure.)
I get the following warning which indicates why the stats are not calculated for all (In the following run only 26520 out of 36622 lines will get the stats.
#use v.in.ogr to import the vector/raster
v.rast.stats map=test1 raster=precip@PERMANENT column_prefix=precip
WARNING: Not all vector categories converted to raster. Converted 26520 of 36622.
I have run this on grass 7.8 and 8.2
Hemant Bist.
