Many thanks to all...
the problems are:
1)I wish to use a free/libre solution...
2)v.strahler only produce a text file containing the number of streams
of a defined order... but not a map with attributes concerning stream
order...
3) I know Jgrass, it is a good solution but today I wasn't able to run
it... I don't know why... it start but It remain in a frezed situation
("loading workspace, please wait...")
so..
the problem is still not solved...
however, thank you for your help...
Ivan
Il giorno mer, 03/10/2007 alle 11.52 +0100, Carlos "Guâno" Grohmann ha
scritto:
Well, there's v.strahler, but I never had much luck with it. I did got
nice stahler classification using JGrass (http://www.jgrass.org). I
remember that I couldn' t read GRASS rasters directly (although I
should), but I managed to get it working by exporting the raster as an
GRASS ASCII, and then in JGrass, importing and performing the
hidrologic modeling. The raster layers created by JGRASS were
immediately available in GRASS.
Carlos
On 10/3/07, ivan marchesini <marchesini@unipg.it> wrote:
dear users,
wich is the best way to classify a stream vector network using
the
horton strahler method in grass...???
thank you very much....
Ivan
Ti prego di cercare di non inviarmi
files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
grassuser mailing list
grassuser@grass.itc.it
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
