[GRASS-user] strange bug at startup
Hi everyone,
I use grass64 (GRASS 6.4.2svn47095 (2011)) in my kubuntu natty box (11.04) and when i do in the shell
grass64 -gui
there is no problem using wxpython gui, but when i do
grass64 -text
i have this error message :
dickoa@dickoa:/usr/local/src/releasebranch_6_4$ grass64 -text
Cleaning up temporary files …
Starting GRASS …
*** buffer overflow detected ***: /usr/local/grass-6.4.2svn/etc/set_data terminated
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x37)[0x7fd894e151d7]
/lib/x86_64-linux-gnu/libc.so.6(+0xfd0f0)[0x7fd894e140f0]
/usr/local/grass-6.4.2svn/etc/set_data(main+0xc8)[0x401dc8]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff)[0x7fd894d35eff]
/usr/local/grass-6.4.2svn/etc/set_data[0x401959]
======= Memory map: ========
00400000-00405000 r-xp 00000000 08:01 11541089 /usr/local/grass-6.4.2svn/etc/set_data
00604000-00605000 r–p 00004000 08:01 11541089 /usr/local/grass-6.4.2svn/etc/set_data
00605000-00606000 rw-p 00005000 08:01 11541089 /usr/local/grass-6.4.2svn/etc/set_data
00606000-00607000 rw-p 00000000 00:00 0
01f5e000-01f7f000 rw-p 00000000 00:00 0 [heap]
7fd8948fd000-7fd894912000 r-xp 00000000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7fd894912000-7fd894b11000 —p 00015000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7fd894b11000-7fd894b12000 r–p 00014000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7fd894b12000-7fd894b13000 rw-p 00015000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7fd894b13000-7fd894b15000 r-xp 00000000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7fd894b15000-7fd894d15000 —p 00002000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7fd894d15000-7fd894d16000 r–p 00002000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7fd894d16000-7fd894d17000 rw-p 00003000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7fd894d17000-7fd894ea1000 r-xp 00000000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7fd894ea1000-7fd8950a0000 —p 0018a000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7fd8950a0000-7fd8950a4000 r–p 00189000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7fd8950a4000-7fd8950a5000 rw-p 0018d000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7fd8950a5000-7fd8950ab000 rw-p 00000000 00:00 0
7fd8950ab000-7fd89512f000 r-xp 00000000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7fd89512f000-7fd89532e000 —p 00084000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7fd89532e000-7fd89532f000 r–p 00083000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7fd89532f000-7fd895330000 rw-p 00084000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7fd895330000-7fd895370000 r-xp 00000000 08:01 1310781 /lib/libncurses.so.5.7
7fd895370000-7fd89556f000 —p 00040000 08:01 1310781 /lib/libncurses.so.5.7
7fd89556f000-7fd895573000 r–p 0003f000 08:01 1310781 /lib/libncurses.so.5.7
7fd895573000-7fd895574000 rw-p 00043000 08:01 1310781 /lib/libncurses.so.5.7
7fd895574000-7fd895578000 r-xp 00000000 08:01 13503819 /usr/local/grass-6.4.2svn/lib/libgrass_vask.6.4.2svn.so
7fd895578000-7fd895777000 —p 00004000 08:01 13503819 /usr/local/grass-6.4.2svn/lib/libgrass_vask.6.4.2svn.so
7fd895777000-7fd895778000 r–p 00003000 08:01 13503819 /usr/local/grass-6.4.2svn/lib/libgrass_vask.6.4.2svn.so
7fd895778000-7fd895779000 rw-p 00004000 08:01 13503819 /usr/local/grass-6.4.2svn/lib/libgrass_vask.6.4.2svn.so
7fd895779000-7fd89577a000 rw-p 00000000 00:00 0
7fd89577a000-7fd895791000 r-xp 00000000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7fd895791000-7fd895990000 —p 00017000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7fd895990000-7fd895991000 r–p 00016000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7fd895991000-7fd895992000 rw-p 00017000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7fd895992000-7fd89599a000 r-xp 00000000 08:01 13503874 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
7fd89599a000-7fd895b99000 —p 00008000 08:01 13503874 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
7fd895b99000-7fd895b9a000 r–p 00007000 08:01 13503874 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
7fd895b9a000-7fd895b9b000 rw-p 00008000 08:01 13503874 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
7fd895b9b000-7fd895bee000 r-xp 00000000 08:01 13503888 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
7fd895bee000-7fd895ded000 —p 00053000 08:01 13503888 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
7fd895ded000-7fd895dee000 r–p 00052000 08:01 13503888 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
7fd895dee000-7fd895df0000 rw-p 00053000 08:01 13503888 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
7fd895df0000-7fd895df1000 rw-p 00000000 00:00 0
7fd895df1000-7fd895df7000 r-xp 00000000 08:01 13503862 /usr/local/grass-6.4.2svn/lib/libgrass_edit.6.4.2svn.so
7fd895df7000-7fd895ff6000 —p 00006000 08:01 13503862 /usr/local/grass-6.4.2svn/lib/libgrass_edit.6.4.2svn.so
7fd895ff6000-7fd895ff7000 r–p 00005000 08:01 13503862 /usr/local/grass-6.4.2svn/lib/libgrass_edit.6.4.2svn.so
7fd895ff7000-7fd895ff8000 rw-p 00006000 08:01 13503862 /usr/local/grass-6.4.2svn/lib/libgrass_edit.6.4.2svn.so
7fd895ff8000-7fd896019000 r-xp 00000000 08:01 1314421 /lib/x86_64-linux-gnu/ld-2.13.so
7fd8961e4000-7fd8961e9000 rw-p 00000000 00:00 0
7fd896215000-7fd896218000 rw-p 00000000 00:00 0
7fd896218000-7fd896219000 r–p 00020000 08:01 1314421 /lib/x86_64-linux-gnu/ld-2.13.so
7fd896219000-7fd89621b000 rw-p 00021000 08:01 1314421 /lib/x86_64-linux-gnu/ld-2.13.soAborted
I tried to reinstall but i have the same error.
Could someone experienced this kind of error ? there’s a way to fix this ?
