I just computed the slope using r.slope.aspect on the Aster data over the full French territory, and as a result got large artefact stripes on a south west-north east axe? When could it come from (inadequate re-projection, the slope routine or the aster data)?
On Fri, Dec 20, 2013 at 4:54 PM, manuel.martin
<manuel.martin@orleans.inra.fr> wrote:
Do you use these data in their original projection?
BTW:
you may use the new EU-DEM: Digital Surface Model at 25m
> Hi all,
south
the
Hi, I would say that problem is in the DEM. Maybe the DEM needs some
cleanup (such as smoothing by r.neighbors). Using lower resolution (less
detailed) may help (r.resample probably needed). Blue stripes are probably
places where the elevation changes a lot and thus creating slopes.
So, using EU-DEM might be a good solution.
Vaclav
BTW:
ASTER data are not really suitable to derive a DEM, your example is
another demonstration that an ASTER-derived DEM contains artefacts.
SRTM DEMs are without these artefacts.
Thanks for the replies, we actually derived SRTM DEMs and yes this thime without artifacts.
Markus M
----------------0----0------
INRA - InfoSol
Centre de recherche d'Orléans
2163 Avenue de la Pomme de Pin
CS 40001 ARDON
45075 ORLEANS Cedex 2
tel : (33) (0)2 38 41 48 21
fax : (33) (0)2 38 41 78 69 http://www.gissol.fr
----0----0------------------
