Leonidas, you’re facing an issue that arises when you reproject a grid (in your case the DEM)
from a geographic coordinate system (lat-long) to UTM or other planar coordinate system.
When you reproject, the cells will shift and skew a bit, and this will create those ‘fishnet’
lines in your projected raster (you can also see them in a shaded relief).
I discussed it briefly in a IJGIS paper, and to me, the option is to convert your original (latlong) data
to vector points, then project the points to UTM (or other) and then interpolate the vector points
to create a new raster in the new coordinate system. This will eliminate those artifacts.
I also remember that Dylan Baudette had a page showing the outputs from gdalward, and you could see the artifacs there as well, but it seems that page is offline…
Here is the paper:
Grohmann, C.H., Steiner, S.S., 2008. SRTM resample with Short Distance-Low Nugget Kriging.
International Journal of Geographical Information Science, 22 (8):895-906.
direct link (no subscription needed): http://igc.usp.br/pessoais/guano/downloads/Grohmann_Steiner_2008_IJGIS_uncorrected_proof.pdf
best
Carlos
On Thu, Mar 15, 2012 at 11:01, Glynn Clements <glynn@gclements.plus.com> wrote:
leonidas wrote:
Thank you for your answers!
I did g.region rast=aster_dem_ggrs and then I run again r.slope.aspect but
the problem still remains.
Here is the whole process.
- I download the tiles from http://www.gdem.aster.ersdac.or.jp/search.jsp
- Merge them: gdalwarp ASTG mosaic.tif*
- Reproject the raster to greek grid: gdalwarp -s_srs EPSG:4326 -t_srs
EPSG:2100 mosaic.tif dem_temp.tif
This is the problem. Resampling introduces artifacts which affect the
gradient calculation. Ideally, you should calculate the slope and
aspect on the original data, then re-project the result. Failing that,
either use the -r switch to select a more suitable resampling method
(such as cubic, cubicspline or lanczos) or filter the data with e.g.
r.mfilter or r.neighbors prior to running r.slope.aspect.
grass-user mailing list
grass-user@lists.osgeo.org
Prof. Carlos Henrique Grohmann - Geologist D.Sc.
Institute of Geosciences - Univ. of São Paulo, Brazil
Twitter: @CarlosGrohmann
http://carlosgrohmann.tumblr.com/
Can’t stop the signal.
