Jonathan Greenberg <greenberg <at> ucdavis.edu> writes:
Grassers:
I'm using v.surf.rst, and I'm wondering what the best strategies for
getting rid of those rectangular segmentation boxes are, while also not
having the high local peaks around lone sample points? Thanks!
Hi All,
I am having the same issue as Jonathan, I know it is being caused by lack of
data.
Original data is unretrievable, but I did digitalize in GRASS 6.2 from a
scanned paper map.
In the pics, you can see the vector lines in blue (v.digit'ized) and the
raster made with r.surf.rst
Those are isopach (thickness) and sand isolite (sand content [%]) maps. I
digitized the values x100 the original, because of some remark in the GRASS
book, but now I think it applied to r.surf.contour
Note that I don't _need_ to use r.surf.rst, but I _need_ a smooth raster.
Whatever method that is capable of that. Also, vector lines are the best _I_
could do, so no increase in resolution is possible, but alternate methods are
nice =]
In the meantime, I'll try Hamish's suggestion.
http://paulomarcondes.googlepages.com/isopaca.jpg
r.info for this raster:
| Layer: isopaca_sseqC.elev Date: Fri Jun 6 10:45:17 2008 |
| Mapset: PERMANENT Login of Creator: cmp9 |
| DataBase: /u/cmp9/gisdata |
| Title: ( isopaca_sseqC.elev ) |
| timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 1292 |
| Columns: 1166 |
| Total Cells: 1506472 |
| Projection: UTM (zone -24) |
| N: 7668884.01433 S: 7475133.68393 Res: 149.96155604 |
| E: 450329.267038 W: 275417.899494 Res: 150.00974918 |
| Range of data: min = -11.243400 max = 70065.601562 |
| Data Source: |
| vector file isopaca_sseqC |
| Data Description: |
| generated by v.surf.rst |
| Comments: |
| giventension=40.000000, smoothing=0.100000 |
| dnorm=23529.679966, dmin=100.000000, zmult=1.000000 |
| segmax=40, npmin=300, rmsdevi=22.054472 |
| zmin_data=0.000000, zmax_data=70000.000000 |
| zmin_int=-11.243400, zmax_int=70065.601691 |
| v.surf.rst -t input="isopaca_sseqC" layer=1 zcolumn="isopaca" dmax=3\ |
| 50 dmin=100 elev="isopaca_sseqC.elev" slope="isopaca_sseqC.slope" as\ |
| pect="isopaca_sseqC.aspect" pcurv="isopaca_sseqC.curv" tcurv="isopac\ |
| a_sseqC.tancurv" mcurv="isopaca_sseqC.meancurv" maskmap="isopaca_mas\ |
| k" zmult=1 tension=40. segmax=40 npmin=300 |
http://paulomarcondes.googlepages.com/isolita.jpg
r.info:
| Layer: isolita_sseqC.elev Date: Thu Jun 5 15:21:08 2008 |
| Title: ( isolita_sseqC.elev ) |
| timestamp: none |
| Data Type: FCELL |
| Rows: 1292 |
| Columns: 1166 |
| Range of data: min = -93578.492188 max = 804178.500000 |
| Data Source: |
| vector file isolita_sseqC |
| Data Description: |
| Comments: |
| dnorm=33181.595517, dmin=100.000000, zmult=100.000000 |
| segmax=40, npmin=300, rmsdevi=4581.273762 |
| zmin_data=200000.000000, zmax_data=800000.000000 |
| zmin_int=-93578.488628, zmax_int=804178.527938 |
| v.surf.rst input="isolita_sseqC" layer=1 zcolumn="isolita" dmax=350 \ |
| dmin=100 elev="isolita_sseqC.elev" slope="isolita_sseqC.slope" aspec\ |
| t="isolita_sseqC.aspect" pcurv="isolita_sseqC.curv" tcurv="isolita_s\ |
| seqC.tancurv" mcurv="isolita_sseqC.meancurv" maskmap="isolita_mask" \ |
| zmult=100 tension=40. segmax=40 npmin=300 treefile="isolita_quadtree\ |
| " overfile="isolita_windows" |
Also:
GRASS 6.2.3 (Aratu_BC):~/gisdata/Aratu_BC/PERMANENT > g.region -p
projection: 1 (UTM)
zone: -24
datum: ** unknown (default: WGS84) **
ellipsoid: a=6378388 es=0.006722670022333321
north: 7668884.01433
south: 7475133.68393
west: 275417.899494
east: 450329.267038
nsres: 149.96155604
ewres: 150.00974918
rows: 1292
cols: 1166
cells: 1506472
