[GRASS-user] Stuck Getting Started
   It's been about 6 years since I last used GRASS (4.3), but it makes no
sense that I cannot get started on a project now. I'm using the svn download
from several days ago.
   1.) Created the database /usr4/grassdata
   2.) Within /usr4/ started grass: grass64
   3.) Tclgrass display comes up and asks again for the database; I enter
   that.
   4.) Click on 'Create new location using projection data'.
   5.) The antiquated text entry window displays. I again enter the database,
   the new location name (ORdem10), and the mapset (rbs).
   6.) I'm shown the list of coordinate systems and select D; enter the name
   'Oregon Conformal Conic' (which cannot be edited if I mistype a
   letter), and answer 'y' because it's correct.
   7.) Please enter a one line description for location <ORdem10>
ok? (y/n) [y] ERROR: region for current mapset is not set
        run "g.region"
ERROR: "/usr/local/grass-6.4.0RC5/etc/set_data" exited abnormally. Press
<enter> to continue.
   Can't enter the datum, ellipsoid, and other parameters to define this
dataset.
   Where do I start looking for the reason?
Rich
You may find it easier to use the "EPSG codes" button, and pick the
code to match your projection/coordinate system.
There is the epsg and esri projection files. In Karmic Koaloa
Kubuntu, they reside in /usr/share/proj/
Mark
On Fri, Nov 13, 2009 at 1:16 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
that.
run "g.region"
dataset.
Rich
grass-user mailing list
grass-user@lists.osgeo.org
      run "g.region"
dataset.
This sounds to me like a known bug in 6.4.0 RC5 <http://trac.osgeo.org/grass/ticket/648&gt; - maybe try the latest 6.4 SVN snapshot instead of RC5?
Paul
Paul,
   After initially building and installing the stable 6.4.0RC5, I was advised
to grab the svn trunk instead. I did so on Nov 10th. That's the code I built
and installed. Perhaps I need to uninstall and redo the process.
Rich
Richard B. Shepard, Ph.D. | Integrity Credibility
Applied Ecosystem Services, Inc. | Innovation
<http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
Paul,
   Just tried to download the latest code < svn checkout
https://svn.osgeo.org/grass/grass/tags/release_20090609_grass_6_4_0RC5
grass640_rc5> and I already have revision 39721 checked out. So I must be
using the latest.
   In what file is the code for the initial text display in which the
database, location, and map set is specified?
Rich
Paul,
using the latest.
As far as I understand it that just means you are using the latest version of the version tagged release_20090609_grass_6_4_0RC5 - for the latest 6.4 SVN you want the 6.4 branch rather than any specific tagged version:
https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4
should be the one I think.
Paul
https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 should be the
one I think.
Paul,
   Hokay ... did the svn -co to a new directory and at the end I'm told that
I've checked out revision 39721. That's the same revision as before. So I
was using the latest code when I ran into that brick wall.
   I'll take a look at the bug report, too.
Rich
Paul,
   Yup. That's the bug I hit. And did so in the latest svn 6.4 branch
download (build 39721).
Rich
Paul,
   I forgot to mention that I hit this bug regardless of the UI: tcl or
python.
Rich
one I think.
Paul,
Sorry don't think I was clear enough - any branch, tag or version that you update from SVN at this moment in time will show revision 39721, as that is simply the latest change to have been made anywhere in the entire SVN tree.
Paul
tree.
Paul,
   Ah! Now I'm on the same page as you are. I'll build and install and see if
that makes a difference.
Rich
tree.
Paul,
   The latest code fixed the problem. Using the wxPython UI I was able to
specify the data base and name the location and map set. Entering the
projection information went well, except there is no widget to enter units.
That bit me running r.in.gdal from within the GUI. That's another thread.
Many thanks,
Rich
