[GRASS-user] sum of areas of certain attributes
Hello list,
I have a polygon map with a huge table, in which some columns give the information about a classification of the single polygons (these are represnted by single categories). I would like to calculate e.g. the sum of areas belonging to each class. How can I do this
I tried a way by extracting the class needed indiviadually, generating a new tabel and so on, but it seems to be quite complicated. Is there a more simple way to get the results?
Thanks!
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
On 15/11/07 08:27, Dr. Manuel Seeger wrote:
Hello list,
v.to.db with option=area ?
Moritz
[please always cc the list to let everyone profit of the discussion]
On 15/11/07 11:10, Dr. Manuel Seeger wrote:
Thanks Moritz,
but I think I did not explain clear enough.
v.to.db calculates the values for each category (here this is each polygon), but I need the sum of values for different classes, which are composed by a changing number of polygons. I want to know the area of each class.
After running v.to.db, you can run a select on the classification column. Something like:
echo "select sum(area) from TABLE group by ClassificationColumn" | db.select
If your classification information is in integer form, you can also use v.reclass:
v.reclass in=OrigMap out=ReclassMap Column=ClassificationColumn
and then v.to.db on ReclassMap.
Moritz
how?
Thank you!
Manuel
Hello list,
Moritz
