[GRASS-user] summing rasters with a condition given by other rasters
I have the following issue to solve:
There is a MODIS NDVI time series with 23 images for one year, named ndvi_01
to ndvi_23. Then i have a
raster with integer values from 1-23 representing the start of the growing
season (SOS), and the end (EOS), the values differ for each pixel. What i am
trying to do is to create a raster which averages (or sums) all NDVI values
from ndvi_01 to ndvi_23 which are between SOS and EOS, for an example pixel
where SOS is 13 and EOS is 21 that would be an average of the 9 pixels in
ndvi_13 to ndvi_21.
Is this possible with GRASS 7 under Ubuntu?
kind regards,
Martin
View this message in context: http://osgeo-org.1560.x6.nabble.com/summing-rasters-with-a-condition-given-by-other-rasters-tp5206108.html
* Martin_Brandt <martin.brandt@mailbox.org> [2015-05-17 12:44:33 -0700]:
ndvi_13 to ndvi_21.
kind regards,
Martin
Dear Martin,
this sounds like a perfect use-case for the spatio-temporal framework.
Take care to timestamp your maps correctly (each NDVI image should carry
the time of acquisition of its originating MODIS scene I guess).
Then, create a spatio-temporal raster data set (strds) with `t.create` and register
your maps in it with `t.register`.
Though I don't understand the pattern in the SOS image, you have the
`t.rast.mapcalc` tool to do all sorts of magic for the strds (as you would regularly do for
single raster images).
Check in the GRASS wiki an example on using the temporal framework
<http://grasswiki.osgeo.org/wiki/Temporal_data_processing&gt;\.
There is also the tutotial at
<http://ncsu-osgeorel.github.io/grass-temporal-workshop/&gt;\. Both are
excellent.
Best of success, Nikos
Hi Martin
According to the data you have, you may wanna register your ndvi maps
as relative time, and then:
# with this you select maps between dates pointed out in your sos and
eos maps and put null everywhere else
t.rast.mapcalc -n input=ndvi output=ndvi_sos_eos base=ndvi_sos_eos
expr="if(start_time() >= sos && start_time() <= eos, ndvi, null())"
# and here you estimate the average and sum for the stored ndvi data
for m in 'average sum' ; do
t.rast.series input=ndvi_sos_eos output=ndvi_sos_eos_${m} method=${m}
done
it should work, but i did not test... let me know if it was of any help :slight_smile:
cheers,
Vero
2015-05-18 4:43 GMT-03:00 Nikos Alexandris <nik@nikosalexandris.net>:
ndvi_13 to ndvi_21.
kind regards,
Martin
Dear Martin,
excellent.
grass-user mailing list
grass-user@lists.osgeo.org
it works great and is amazingly fast, a comparable operation in R needs 30
minutes while it's done in GRASS in 20 seconds. There seems to be a great
potential of this new tool, thanks Veronica and Nikos!
View this message in context: http://osgeo-org.1560.x6.nabble.com/summing-rasters-with-a-condition-given-by-other-rasters-tp5206108p5206484.html
