Hi Markus,
As to the training area I draw just one, which is fearly small because it's homogeous with rispect to the color I want to sample. I've tried to select other areas in the same section, using the command "draw region", but apparently I'm not allowed to do it.
I always close the training areas with the "complete button".
Here it's the procedure I'm following
1. i.group (to create group A and subgroup rgb)
2. d.mon
3. i.class map=ortophoto_composite group=A subgroup=rgb outsig=test (I can see the file test being created in the folder .../subgroup/$SUBGROUP/sig/; it's now 0 Byte)
4. from the interactive i.class menu, I select "Zoom"; then once the zoomed area is displayed, "Define Region" and "Draw Region". I draw 1 area by points, then I click on "Complete Region" and "Done". As I return to the main menu, I click on "analyse region" -> Signature Menu, "Display matches", "Done". save Signature YES, then I'm prompted for the signature description; finally I Quit from the main menu. Now I can see the file size has increased to 14 Byte. When I edit it, I can see only 3 lines.
I've also tried selecting a much larger area for which the histogramm is smoother that in the previous case, nothing has changed, still 3 lines in the outsig file.
Silvia
On Sep 4, 2008, at 9:52 PM, Markus Neteler wrote:
On Thu, Sep 4, 2008 at 6:24 PM, Silvia Simoni
<silvia.simoni@ing.unitn.it> wrote:
Thanks Markus!
I'm now using grass6.4.svn but I still have trouble with the supervised
classification process. Now I can run i.class and produce the spectral
signature for my map but this file is NOT readable by i.maxlik. I get the
following message: Can't read signature file [signaturefile].
I checked in $MAPSET/group/subgroup/$SUBGROUP/sig/; the signaturefile is
there but it only contains 3 lines, as follows:
#comment
single value XXXX
Is this correct? I obtained other signature files from i.cluster which look
different from this. It seems to me that i.class doesn't write the signature
file correctly so that i.maxlik is not able to read it.
It doesn't look good.
But a quick test here didn't show any problem.
Are you sure that
- your training areas are big enough in i.class?
- that you close the training areas with the "complete" button?
Silvia Simoni PhD
DICA - Department of Civil and Environmental Engineering
Universita' di Trento
via Mesiano 77, 38100 Trento, ITALY
tel. +39 0461 882610
fax. +39 0461 882672
e-mail: silvia.simoni@ing.unitn.it
