Hi Users,
I want to know if there is any good sources of information on the above wxlClass. I want to know roughly how large the training areas should be to prevent the module from taking several hours to process a signature. Also in the Training Area Display must i use a composite RGB image to digitise a training area from or will a single channel be okay?
Many thanks,
Paul J. Shapley MSc CGeog (GIS) FRGS
Am 1. Juni 2018 11:26:22 MESZ schrieb Paul Shapley <p.shapley@gmail.com>:
Hi Users,
to
I haven't had this experience. Check your region settings. Maybe that explains long run times.
Also
digitise a
You can use whatever suits you. Often it is advisable to display different bands and composites and switch between them according to need.
Moritz
Many thanks,
Hi Users,
Many thanks,
