[GRASS-user] suppress output to terminal completely
Hi list,
I’m working with r.le.patch in both scripts as well as interactively on the terminal.
Since these calculations take up a lot of time I would like to move them to the background.
If I use r.le.patch -mysettings & this will do just that.
However, the module still spews stuff to my terminal. This is very annoying as I login remotely so I can’t fall back on the GUI menus.
Can I disable my terminal output completely?
dumping stout to /dev/null does not seem to work…
Any ideas, this would make GRASS workable again…
Koen
On Mon, 29 Dec 2008, Hufkens Koen wrote:
Hi list,
I'm working with r.le.patch in both scripts as well as interactively on the terminal.
However, the module still spews stuff to my terminal. This is very annoying as I login remotely so I can't fall back on the GUI menus.
dumping stout to /dev/null does not seem to work...
GRASS modules send informative messages to stderr, not stdout - so adding
2>/dev/null
(Bash shell syntax) should work. But have you tried r.le.patch --quiet first of all? I'm not sure if r.le.patch respects the --quiet setting, but redirecting stderr to /dev/null definitely will work.
Paul
I use the --quiet option but then the output changes from
tracing patch 1
tracing patch 2
etc…
to tracing patch 1 and then only flipping this number and not rewriting the line.
So it does not respect the --quiet option completely…
And the 2> /dev/null option seems to work, now my script can run in the background and I can keep working.
Koen
-----Original Message-----
From: Paul Kelly [mailto:paul-grass@stjohnspoint.co.uk]
Sent: Mon 29-12-2008 17:36
To: Hufkens Koen
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] suppress output to terminal completely
Hi list,
2>/dev/null
first of all? I’m not sure if r.le.patch respects the --quiet setting, but
Paul
