[GRASS-user] surface roughness script
Dear list
I have uploaded in the WIKI r.roughness, a script to calculate maps of
surface roughness for a DEM.
# MODULE: r.roughness
# AUTHOR(S): Carlos H. Grohmann <carlos dot grohmann at gmail dot com >
# PURPOSE: Calculates surface roughness from DEMs. (uses r.surf.area)
# In this script surface roughness is used in the sense of
# Hobson (1972), who describes it as the ratio between surface
# (real) area and flat (plan) area of square cells; in this
# approach, flat surfaces would present values close to 1,
# whilst in irregular ones the ratio shows a curvilinear
# relationship which asymptotically approaches infinity as the
# real areas increases.
# Reference:
# Hobson, R.D., 1972. Surface roughness in topography:
# quantitative approach. In: Chorley, R.J. (ed) Spatial
# analysis in geomorphology. Methuer, London, p.225-245.
# This script will create sub-regions with size defined by
# the option GRID. In each sub-region, the real and planar areas
# will be calculated by r.surf.area, and the results (points at
# the center of sub-regions) will be interpolated with v.surf.rst.
# The user also can set the tension and smooth parameters.
All the best
Carlos
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Great!
This looks extremely useful.
PS: I was just reading one of your papers where you describe this method.
Dylan
On Wednesday 19 July 2006 14:32, Carlos "Guâno" Grohmann wrote:
Dear list
# Reference:
All the best
Carlos
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
