If there is a stable -6.4 release that's updated weekly, why is there also
a -6.4 release candidate 5 branch? My understanding is that release
candidates precede releases and are mooted once the version has been
released.
Confused,
Rich
released.
Confused,
Rich
On Wed, Feb 17, 2010 at 3:34 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
released.
Please indicate the URLs to better understand the confusion.
We have
- 6.4.release-branch from which RC5 was extracted some months ago
-> weekly source code and Linux binary snapshots are generated
-> daily winGRASS binaries are generated
- 6.5.devel-branch
- 7.trunk
If you indicate the suboptimal web page(s), we may be able to
clarify things there, too.
On Wed, 17 Feb 2010, Markus Neteler wrote:
We have
Markus,
Do I interpret the above that you extracted RC5 from the stable release?
Here's the URL: <http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS6.4>
and this is what I see:
GRASS 6.4
To extract the current 6.4.0 release candidate 5 (RC5) use the command:
svn checkout https://svn.osgeo.org/grass/grass/tags/release_20090609_grass_6_4_0RC5 grass640_rc5
To extract the current 6.4.x release branch version (stable) use the command:
svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 grass64_release
Are you developing both the stable and release candidate versions
simultaneously? Do both have identical code? If I want the patch you added
late last week which branch do I use?
Rich
On Wed, Feb 17, 2010 at 4:55 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
We have
-> daily winGRASS binaries are generatedMarkus,
and this is what I see:GRASS 6.4
svn checkout
grass640_rc5To extract the current 6.4.x release branch version (stable) use the
command:svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4
grass64_release
Now I understand your confusion.
I have inverted the order and changed the wording to
GRASS 6.4
To extract the current state of the 6.4.x release branch version
(stable), use the command:
grass64_release
To extract the 6.4.0 release candidate 5 (RC5) from 2009, use the command:
grass640_rc5
Does it make more sense now?
then use "the current state of the 6.4.x release branch" (so the upper after the
modification).
You can simply stay on that branch and update with
svn up
from time to time to fetch latest fixes. I am using that for my production
systems.
Whew!
GRASS 6.4
grass64_releaseTo extract the 6.4.0 release candidate 5 (RC5) from 2009, use the command:
grass640_rc5Does it make more sense now?
It certainly does, Markus.
after the modification).
That's what I thought and what I've been doing.
Many thanks,
Rich
