I'm trying to checkout the code from SVN but when I issue the command
svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6
grass6_devel
I get the following error:
svn: OPTIONS of
'https://svn.osgeo.org/grass/grass/branches/develbranch_6’: could not
connect to server (https://svn.osgeo.org)
Is it me? Or is the server experiencing problems?
Thanks
Daniel
On Mon, Aug 16, 2010 at 11:57 PM, Daniel Victoria
<daniel.victoria@gmail.com> wrote:
grass6_devel
svn: OPTIONS of
Is it me?
Try
http://downforeveryoneorjustme.com/
From Italy it looks good at time, no problems.
It's probably some local problem then.... I can ping the server but
can't checkout the code...
Daniel
grass6_devel
svn: OPTIONS of
Is it me?
Try
Well, I'm a bit embarrassed but I found the problem... Wrong proxy
settings.... I checked out the code from SVN just fine but now I'm
having problems compiling.
I get errors in lib/gmath that says:
/home/daniel/grass/grass6_devel/lib/gmath/blas_level_1.c:91:
undefined reference to `sqrt'
Am I missing some library?
Daniel
On Mon, Aug 16, 2010 at 8:57 PM, Daniel Victoria
Daniel
grass6_devel
svn: OPTIONS of
Is it me?
Try
No; it's a bug in lib/gmath/Makefile, which should have $(MATHLIB) in
the definition of EXTRA_LIBS.
$(MATHLIB) (typically -lm) will usually get pulled in anyhow (e.g. via
$(FFTWLIB)), hence the reason that no-one has noticed this before.
Got it working now! I did not have FFTW included in the compilation.
Once I installed the libraries and set the --with-fftw flag it all
worked. Grass 6.5 looks very nice. I'm particularly eager to try out
the modeler
Looks very nice! Congrats all!
Daniel
On Wed, Aug 18, 2010 at 2:43 AM, Glynn Clements
2010/8/18 Daniel Victoria <daniel.victoria@gmail.com>:
the modeler
the modeler is under active development. Please report bugs or wishes
on trac if needed.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Fixed in r43160.
Glynn:
> > $(MATHLIB) in the definition of EXTRA_LIBS.
> Fixed in r43160.
backport to 6.4?
Yes.
