I want to use ‘r.to.vect’ but it seems to default to a ‘Postgis’ table that has no geometry column just a table with a ‘cat’ id. I would like to export to ‘sqlite’. I have both postgres an sqlite login details stored in ‘db.login’. How do i switch between the two or at least make sqlite the default? If I change settings with ‘db.connect’ to ‘sqlite’ it fails (error below) but still keeps holding onto the ‘grass_gis’ schema form the Postgis connection!
r.to.vect input=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs@PERMANENT output=test1 type=area
DBMI-SQLite driver error:
Error in sqlite3_prepare():
unknown database grass_gis
ERROR: Unable to create table: create table grass_gis.test1 ( cat integer, value integer, label varchar(10))
WARNING: Table <grass_gis.test1> linked to vector map does not exist
Is there a preferred option to change databases more cleanly.
what is the exact command you used to set the default connection to sqlite?
You can also try db.connect -d, otherwise you might need to specify the default database to be used.
In any case, please verify first with db.connect -p to see the connection details used when creating a new vector.
Markus M
Default driver / database set to:
driver: sqlite
database: C:\TempLocation\PERMANENT\sqlite\sqlite.db
(Mon Jul 02 14:19:40 2018) Command finished (0 sec)
Still holding ‘schema’ and ‘group’ details from PostGIS. Shouldn’t these have been dropped when changing to sqlite which is perhaps why the connection is failing?
Markus M
yes.
It seems that db.connect -g is better than db.connect -p to verify connection settings, e.g. I get in the North Carolina sample dataset
Markus M
yes.
Markus M
yes.
Markus M
Le Mon, 2 Jul 2018 16:36:30 +0200,
Markus Metz <markus.metz.giswork@gmail.com> a écrit :
On Mon, Jul 2, 2018 at 4:04 PM, Paul Shapley <p.shapley@gmail.com>
wrote:
> Hi Markus,
> Used 'db.connect' driver=sqlite
database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> I had to delete 'database schema=grass_gis'
> I had to delete 'default group=postgis_reader'
That seems to be a bug in db.connect, apparently it is not possible to
reset schema and group. Can you please open a ticket?
AFAIR, schema= and group= (i.e. without any value) should reset these
parameters.
yes.
Markus M
Am 2. Juli 2018 21:06:15 MESZ schrieb Markus Metz <markus.metz.giswork@gmail.com>:
On Mon, Jul 2, 2018 at 4:54 PM, Moritz Lennert
<mlennert@club.worldonline.be>
> wrote:
> > Hi Markus,
to
parameters.
That means no answer to schema and group would be a reasonable default
answer in order to easily change the current connection parameters?
No, should was the wrong word: does would have been better. AFAIR, explicitly setting them to no answer already did reset them.
