[GRASS-user] Syncronizing two displays
Is there a way to link two map displays in grass so that when I zoom into one display, the other follows? This would be very usefull for comparing raster and vector data, for instance.
Daniel
On Tue, Mar 3, 2015 at 1:18 PM, Daniel Victoria
For example, the g.gui.mapswipe does this.
Hi Markus,
Thanks, g.gui.mapswipe seems very nice. I just haven’t been able to use it because it’s not loading my data. I’m trying to use it for comparing vector networks (31 thousand lines). I can load the left layer but when I try to load the right layer, the dialogs just won’t respond.
Does g.gui.swipe works vectors?
I’m using Grass 7 from OSGeo4Win
Thanks
Daniel
On Wed, Mar 4, 2015 at 6:22 AM, Daniel Victoria <daniel.victoria@gmail.com>
wrote:
Hi Markus,
Thanks, g.gui.mapswipe seems very nice. I just haven't been able to use it
because it's not loading my data. I'm trying to use it for comparing vector
load the right layer, the dialogs just won't respond.
In the input dialog, you can specify only raster data, but there is a
button 'switch to advanced mode' and there you can upload any combination
of different data.
Anna
I'm using Grass 7 from OSGeo4Win
Thanks
Daniel
into
grass-user mailing list
grass-user@lists.osgeo.org
