[GRASS-user] t.create error: Unable to connect to psycopg2 database: newdb
I'm having some trouble with t.create/t.connection and postgresql.
t.create is giving the following error on attempting to create a raster
space time dataset in postgresql, and then I'm also subsequently unable to
create a space time database in sqlite?
I'd be grateful for any suggestions on how to resolve.
Richard
For example:
# set connection in t.connect and try and create dataset:
t.connect driver=pg database=newdb
(I've also tried t.connect driver=pg database="newdb user=user
password=*******")
The VAR file contains the new settings.
t.create --overwrite output=teststrds type=stvds semantictype=max title=t
description=d
ERROR: Unable to connect to psycopg2 database: newdb
Exception: "missing "=" after "newdb" in connection info string
Please use t.connect to set a read- and writable temporal database backend
I then try to create a temporal dataset in sqlite, but I then get an error
with sqlite?
t.connect database=/home/rcooper/grassdatacl/climdata/newdb/tgis/sqlite.db
t.connect -p
driver:sqlite
database:/home/rcooper/grassdatacl/climdata/newdb/tgis/sqlite.db
t.create --overwrite output=test_sq_strds type=stvds semantictype=max
title=t description=d
Creating temporal database:
NOTE: I can connect to the postgresql database with db.login and db.connect,
so it doesn't seem to be a permissions issue.
db.login driver=pg database=newdb user=user password=*****
db.connect -p database=newdb
driver: pg
database: newdb
schema: public
group:
System:
GRASS version: 7.0.1svn
GRASS SVN Revision: 65041
Build Date: 2015-04-10
Build Platform: x86_64-unknown-linux-gnu
GDAL/OGR: 1.11.2
PROJ.4: 4.9.0
GEOS: 3.4.2
SQLite: 3.8.2
Python: 2.7.6
wxPython: 2.8.12.1
Platform: Linux-3.13.0-95-generic-x86_64-with-LinuxMint-17.1-rebecca
View this message in context: http://osgeo-org.1560.x6.nabble.com/t-create-error-Unable-to-connect-to-psycopg2-database-newdb-tp5296563.html
I upgraded to 7.0.6 and I can now reset the database to sqlite, but still
cannot connect to a PostgreSQL database. I'll check again on the t.connect
commands. Does anyone else have any trouble connecting to a potgresql db
with t.connect and creating a temporal dataset with t.create?
View this message in context: http://osgeo-org.1560.x6.nabble.com/t-create-error-Unable-to-connect-to-psycopg2-database-newdb-tp5296563p5296586.html
On Sat, Nov 19, 2016 at 4:35 PM, RichardCooper <richtcooper@hotmail.com> wrote:
Would you mind to make a try with GRASS GIS 7.2.0RC2? You can install
it in parallel.
Replying somewhat late to my query last year, but I'm still getting the same
error with regard to using t.create with a PostgreSQL database connection
with GRASS 7.2.0
t.connect driver=pg database=grasscldb
(Sat May 6 20:36:01 2017) Command finished (0 sec)
(Sat May 6 20:36:08 2017)
t.connect -p driver=pg database=grasscldb
driver:pg
database:grasscldb
(Sat May 6 20:36:08 2017) Command finished (0 sec)
t.create --overwrite output=cahpc_test_strd temporaltype=relative
semantictype=max title=title test description=descr test
ERROR: Unable to connect to psycopg2 database: grasscldb
Exception: "missing "=" after "grasscldb" in connection info string
(Sat May 6 20:37:36 2017) Command finished (0 sec)
System Info
GRASS version: 7.2.0
GRASS SVN revision: exported
Build date: 2017-04-07
Build platform: x86_64-pc-linux-gnu
GDAL: 1.11.2
PROJ.4: 4.9.0
GEOS: 3.4.2
SQLite: 3.8.2
Python: 2.7.6
wxPython: 2.8.12.1
View this message in context: http://osgeo-org.1560.x6.nabble.com/t-create-error-Unable-to-connect-to-psycopg2-database-newdb-tp5296563p5319598.html
