Hello:
I’m trying to do pattern detection of an STRDS (hourly precipitation from radar images) with a cycle of 3 hrs. The last step, t.rast.accdetect errors as follows (after finishing to create the pattern rasters):
File “/usr/lib/grass72/scripts/t.rast.accdetect”, line 592, in
ERROR: Unable to main()
execute transaction: File “/usr/lib/grass72/scripts/t.rast.accdetect”, line 437, in main
INSERT INTO raster_base ( name ,creator ,mapset ,creation_time
,temporal_type ,id ) VALUES (‘pat_2016_07_12_10’ ,‘micha’ ,‘micha’
,‘2017-07-09 23:51:24.106063’ ,‘absolute’ ,‘pat_2016_07_12_10@micha’) ;
INSERT INTO raster_absolute_time ( start_time ,idregister_null, empty_maps, dbif)
,end_time ) File “/usr/lib/grass72/scripts/t.rast.accdetect”, line 479, in create_strds_register_maps
VALUES
(‘2016-07-12 10:00:00’ ,‘pat_2016_07_12_10@micha’ ,‘2016-07-12 11:00:00’) ;
INSERT INTO raster_spatial_extent ( north ,bottom ,west ,top ,proj ,east
,id ,south ) VALUES (-3758645.000000 ,0.000000 ,-523462.000000 ,0.000000
,‘XY’ ,376538.000000 ,‘pat_2016_07_12_10@micha’ ,-4658645.000000) ;
INSERT INTO raster_metadata ( max ,rows map.insert(dbif)
,min File “/usr/lib/grass72/etc/python/grass/temporal/abstract_map_dataset.py”, line 275, in insert
,datatype ,number_of_cells
,cols ,ewres ,nsres ,id ) VALUES (2.000000 ,900 ,1.000000 ,‘CELL’ ,810000
,900 return AbstractDataset.insert(self, dbif=dbif, execute=execute)
,1000.000000 ,1000.000000 File “/usr/lib/grass72/etc/python/grass/temporal/abstract_dataset.py”, line 405, in insert
INSERT INTO raster_stds_register ( id ,registered_stds ) VALUES
(‘pat_2016_07_12_10@micha’ ,NULL) ;
dbif.execute_transaction(statement)
File “/usr/lib/grass72/etc/python/grass/temporal/core.py”, line 1021, in execute_transaction
return self.connections[mapset].execute_transaction(statement)
File “/usr/lib/grass72/etc/python/grass/temporal/core.py”, line 1315, in execute_transaction
self.cursor.executescript(statement)
sqlite3.IntegrityError: UNIQUE constraint failed: raster_base.id
If I understand correctly, the ‘id’ (Primary Key) in raster_base is created from the raster name and mapset. So why am I getting this “UNIQUE constraint failed” error? Any tips?
Thanks, Micha
