[GRASS-user] t.rast.mapcalc question
Dear GRASS users:
I’m experienced grass user… I use GRASS since I started my PhD research in landscape ecology back in 2009…
I’m trying to calculate the difference of NDVI between consecutive dates. I used to do it like:
i=0
for map in $(g.list rast pattern=MOD13Q1*01*); do
NDVI[i]=$map
echo "Adding: " $map
let i=i+1
done
for id in $(seq 0 $(echo ${#NDVI[@]})); do
echo $id
r.mapcalc “ndvi_dif2_$id = ${NDVI[$id+1]} - ${NDVI[id]}”
done
But i thing there must be an easier way using the grass 7 temporal framework. So i registred my dataset and tried the following…
t.rast.list input=ndvi@ts
MOD13Q1.A2009001.h12v12.005.2009019145228_01_4326|ts|2009-01-01 00:00:00|2009-01-17 00:00:00
MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326|ts|2009-01-17 00:00:00|2009-02-02 00:00:00
MOD13Q1.A2010337.h12v12.005.2010355100650_01_4326|ts|2010-12-03 00:00:00|2010-12-19 00:00:00
MOD13Q1.A2010353.h12v12.005.2011005202724_01_4326|ts|2010-12-19 00:00:00|2011-01-04 00:00:00
t.rast.mapcalc input=ndvi expression=“ndvi[1] - ndvi[0]” output=ndvi_a basename=ndvi_a
But the output is not good (see attached file: left is OK, rigth is wrong)
Am I doing something wrong?
Thanks!
(attachments)
Dr. Leonardo A. Hardtke
Laboratorio de Teledetección y S.I.G.
Centro Nacional Patagónico (CONICET)
Bvd. Brown 2825, 9120
Puerto Madryn, Chubut, Argentina
Hola Leo!
You should use t.rast.algebra (https://grass.osgeo.org/grass71/manuals/t.rast.algebra.html) from GRASS GIS 7.1 for that kind of temporal algebra operation. The command should be like:
t.rast.algebra expression=“ndvi_a = ndvi[1] - ndvi[0]” basename=ndvi_a
For more examples on temporal modules, you can see:
https://grasswiki.osgeo.org/wiki/Temporal_data_processing
HTH,
Vero
2015-08-27 9:52 GMT-03:00 Leonardo Hardtke <leohardtke@gmail.com>:
Dear GRASS users:
i=0
NDVI[i]=$map
let i=i+1
done
echo $id
done
Thanks!
grass-user mailing list
grass-user@lists.osgeo.org
Oh! Thanks!
I was using GRASS 7.0.1, which has no t.rast.algebra module.
I didn’t noticed there where a t.rast.mapcalc and a t.rast.algebra in newer versions…
I installed grass71 and as you said,
t.rast.algebra expression=“ndvi_diff = ndvi[0] - ndvi[1]” basename=ndvi_diff
worked perfect! Much easy than the old mapcalc and for loop version!
I’m really enjoying the grass 7 temporal framework!
Thanks for the fast (and accurate) answer!
2015-08-27 10:04 GMT-03:00 Veronica Andreo <veroandreo@gmail.com>:
Hola Leo!
HTH,
Vero
Dear GRASS users:
i=0
NDVI[i]=$map
let i=i+1
done
echo $id
done
Thanks!
