[GRASS-user] t.register does not register anything in a STVDS
Hello,
I created an empty STVDS that looks fine:
t.info input=water_levels_20150801@kolkata type=stvds
+-------------------- Space Time Vector Dataset -----------------------------+
+-------------------- Basic information -------------------------------------+
| Id: ........................ water_levels_20150801@kolkata
| Name: ...................... water_levels_20150801
| Mapset: .................... kolkata
| Creator: ................... laurent
| Temporal type: ............. absolute
| Creation time: ............. 2017-02-23 19:18:15.120512
| Modification time:.......... 2017-02-23 19:18:15.120516
| Semantic type:.............. mean
+-------------------- Absolute time -----------------------------------------+
| Start time:................. None
| End time:................... None
| Granularity:................ None
| Temporal type of maps:...... None
+-------------------- Spatial extent ----------------------------------------+
| North:...................... None
| South:...................... None
| East:.. .................... None
| West:....................... None
| Top:........................ None
| Bottom:..................... None
+-------------------- Metadata information ----------------------------------+
| Vector register table:......
vector_map_register_c14262576ea94a78a55b48b65a72b3a6
| Number of points ........... None
| Number of lines ............ None
| Number of boundaries ....... None
| Number of centroids ........ None
| Number of faces ............ None
| Number of kernels .......... None
| Number of primitives ....... None
| Number of nodes ............ None
| Number of areas ............ None
| Number of islands .......... None
| Number of holes ............ None
| Number of volumes .......... None
| Number of registered maps:.. None
| Title:
| water_levels
| Description:
| Command history:
| # 2017-02-23 19:18:15
| t.create --overwrite output="water_levels_20150801"
| type="stvds" semantictype="mean" title="water_levels" description=" "
I have a maplist file in the form:
water_levels_20150731000000|2015-07-31 00:00:00
water_levels_20150731001500|2015-07-31 00:15:00
[snip]
water_levels_20150801233000|2015-08-01 23:30:00
water_levels_20150801234500|2015-08-01 23:45:00
The vector maps look sane:
v.info map=water_levels_20150731021500@kolkata
| Mapset: kolkata |
| Database: /home/laurent/grassdata |
| Title: |
| Map scale: 1:1 |
| Name of creator: laurent |
| Organization: |
| Source date: Thu Feb 23 18:50:06 2017 |
| Timestamp (first layer): 31 Jul 2015 02:15:00 |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 3 Number of centroids: 0 |
| Number of lines: 0 Number of boundaries: 0 |
| Number of areas: 0 Number of islands: 0 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: UTM (zone 45) |
| N: 2495814.59574642 S: 2492825.11903619 |
| E: 645063.06070329 W: 641365.09898322 |
| Digitization threshold: 0 |
| Comment: |
t.register seems to works fine:
t.register --overwrite --verbose type=vector
file=/home/laurent/Datos_geo/kolkata/one_rainfall_event_of_2015/wl_register_list.txt
Gathering map information...
Registering maps in the temporal database...
But no map is added to the STVDS. If I run t.info again, I get the
exact same results as above.
Strangely, if I run t.register without the --overwrite flag, I get the
following error:
t.register --verbose type=vector
WARNING: Map is already registered in temporal database. Unable to
update vector map <water_levels_20150731000000@kolkata>. Overwrite
flag is not set.
[snip]
But again, t.info or t.vect.list don't show any map.
By opening the SQLite DB, I can see that:
- the vector maps appear in 'vector_spatial_extent', with the extent filled-up
- the vector maps appear in 'vector_absolute_time', with the correct start time
- the values in 'vector_metadata' seem correct
- the vector maps appear in 'vector_stds_register', but the column
'registered_stds' is empty
Is there something I'm missing?
Laurent
You need to specify the name of the stvds in t.register.
Am 24.02.2017 02:48 schrieb “Laurent C.” <lrntct@gmail.com>:
Hello,
±------------------- Space Time Vector Dataset -----------------------------+
±------------------- Basic information -------------------------------------+
| Id: … water_levels_20150801@kolkata
| Name: … water_levels_20150801
| Mapset: … kolkata
| Creator: … laurent
| Temporal type: … absolute
| Creation time: … 2017-02-23 19:18:15.120512
| Modification time:… 2017-02-23 19:18:15.120516
| Semantic type:… mean
±------------------- Absolute time -----------------------------------------+
| Start time:… None
| End time:… None
| Granularity:… None
| Temporal type of maps:… None
±------------------- Spatial extent ----------------------------------------+
| North:… None
| South:… None
| East:… … None
| West:… None
| Top:… None
| Bottom:… None
±------------------- Metadata information ----------------------------------+
| Vector register table:…
| Number of points … None
| Number of lines … None
| Number of boundaries … None
| Number of centroids … None
| Number of faces … None
| Number of kernels … None
| Number of primitives … None
| Number of nodes … None
| Number of areas … None
| Number of islands … None
| Number of holes … None
| Number of volumes … None
| Number of registered maps:… None
| Title:
| water_levels
| Description:
| Command history:
| t.create --overwrite output=“water_levels_20150801”
| type=“stvds” semantictype=“mean” title=“water_levels” description=" "
[snip]
| Mapset: kolkata |
| Title: |
| Map scale: 1:1 |
| Organization: |
Map format: native
Map is 3D: No
Comment:
Gathering map information…
Registering maps in the temporal database…
following error:
update vector map water_levels_20150731000000@kolkata. Overwrite
flag is not set.
[snip]
But again, t.info or t.vect.list don’t show any map.
  • the vector maps appear in ‘vector_spatial_extent’, with the extent filled-up
  • the vector maps appear in ‘vector_absolute_time’, with the correct start time
  • the values in ‘vector_metadata’ seem correct
  • the vector maps appear in ‘vector_stds_register’, but the column
    ‘registered_stds’ is empty
Is there something I’m missing?
Laurent
grass-user mailing list
grass-user@lists.osgeo.org
Am 24.02.2017 02:48 schrieb "Laurent C." <lrntct@gmail.com>:
Hello,
On Fri, Feb 24, 2017 at 4:27 AM, Sören Gebbert
At time it is optional:
https://grass.osgeo.org/grass72/manuals/t.register.html
There will be a reason for that but probably a warning should be
printed to avoid this issue? (I also ran into this recently).
Sören,
I was sure I did. Anyway is it expected behaviour to be able to
register maps in the DB without registering them in a STDS?
I agree with Markus that a warning could be useful.
Thanks for the tip.
Laurent
2017-02-23 21:27 GMT-06:00 Sören Gebbert <soerengebbert@googlemail.com>:
Hello,
| Title:
| water_levels
| Description:
| Command history:
[snip]
| Mapset: kolkata
| Title:
| Map scale: 1:1
| Organization:
| Map format: native
| Map is 3D: No
| Comment:
following error:
flag is not set.
[snip]
filled-up
start time
Laurent
2017-02-24 17:53 GMT+01:00 Laurent C. <lrntct@gmail.com>:
Sören,
Yes, it is.
I don't think so, you will get a warning for expected behavior.
Best regards
Soeren
Thanks for the tip.
Laurent
Hello,
| Title:
| water_levels
| Description:
| Command history:
[snip]
| Mapset: kolkata
| Title:
| Map scale: 1:1
| Organization:
| Map format: native
| Map is 3D: No
| Comment:
following error:
flag is not set.
[snip]
filled-up
start time
Laurent
Le Fri, 24 Feb 2017 19:04:50 +0100,
> Sören,
Yes, it is.
Maybe this means that documentation needs to be improved to make it
clear that there are two different processes here, IIUC:
1) Register maps in the database
2) Register maps as being part of a STDS
1) can exist without 2), but you need 1) for 2).
You can do 2) several times to create different STDS, but using the
same maps registered in 1).
t.register allows you to do both 1) _and_ 2), possibly in one single
run, but it is still two different processes.
Sören, please correct me if I'm wrong.
Moritz
Hello,
2017-02-26 14:53 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
Sören,
Yes, it is.
I don’t think so, you will get a warning for expected behavior.
  1. Register maps in the database
  2. Register maps as being part of a STDS
  3. can exist without 2), but you need 1) for 2).
Yes, because 1 (registering maps in the temporal database) is equivalent to timestamping maps, and that is necesary for the further registration of those maps into a specific stds. However, when you only do 2 (register maps into a stds) the module first takes care of registering such maps into the temporal data base (i.e.: assigning timestamps in the temporal database) and then includes them into the stds you pass as input option.
You can register the same maps in several stds, yes. By default they will be in the temporal database.
t.register allows you to do both 1) and 2), possibly in one single
Yes, as said before, 1 and 2 are two different things and t.register does both. If you use t.register without input option you are just assigning timestamps to maps in the temporal database (in the temporal framework), and if you use t.register with the input option you are registering timestamped maps (that were previously registered in the temporal database, either in the same run of the command or a previous one not using input option) into a specific stds.
Sören, please correct me if I’m wrong.
correct us :slight_smile:
I will try to make these differences clearer both in temporal wiki(s) and manuals (will send a diff to any of you these days).
best,
Vero
