[GRASS-user] t.register syntax
   I thought I had recorded the syntax for creating strds's from existing
raster maps, but I neglected to do so. (t.create worked correctly and the
strds exists.)
   This command fails:
t.register -i input=blocked_h maps=`g.list type=raster pattern=blocked_h_*`
type=raster separator=comma start="2013-11-15" increment="1 days"
with a series of error messages like this:
ERROR: Sorry <blocked_h_0002> is not a valid option
   The maps to be registered are:
blocked_h_0001
blocked_h_0002
blocked_h_0003
blocked_h_0004
blocked_h_0005
blocked_h_0006
blocked_h_0007
blocked_h_0008
blocked_h_0009
blocked_h_0010
blocked_h_0011
blocked_h_0012
blocked_h_0013
blocked_h_0014
blocked_h_0015
blocked_h_0016
blocked_h_0017
blocked_h_0018
blocked_h_0019
blocked_h_0020
blocked_h_0021
blocked_h_0022
blocked_h_0023
blocked_h_max
   I'm not seeing the parameter that I've not entered or the one that should
be entered. Please correct my syntax and this time I'll be certain to write
it down!
TIA,
Rich
Use the comma separator option for g.list since a comma separated list
of maps is required for the maps option in t.register.
2017-03-23 0:16 GMT+01:00 Rich Shepard <rshepard@appl-ecosys.com>:
strds exists.)
  This command fails:
blocked_h_0001
blocked_h_0002
blocked_h_0003
blocked_h_0004
blocked_h_0005
blocked_h_0006
blocked_h_0007
blocked_h_0008
blocked_h_0009
blocked_h_0010
blocked_h_0011
blocked_h_0012
blocked_h_0013
blocked_h_0014
blocked_h_0015
blocked_h_0016
blocked_h_0017
blocked_h_0018
blocked_h_0019
blocked_h_0020
blocked_h_0021
blocked_h_0022
blocked_h_0023
blocked_h_max
it down!
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
try this command
t.register -i input=blocked_h maps=g.list raster pattern=blocked_h_* separator=comma type=raster start=“2013-11-15” increment=“1 days”
2017-03-22 20:25 GMT-03:00 Sören Gebbert <soerengebbert@googlemail.com>:
I thought I had recorded the syntax for creating strds’s from existing
strds exists.)
This command fails:
t.register -i input=blocked_h maps=g.list type=raster pattern=blocked_h_*
type=raster separator=comma start=“2013-11-15” increment=“1 days”
blocked_h_0001
blocked_h_0002
blocked_h_0003
blocked_h_0004
blocked_h_0005
blocked_h_0006
blocked_h_0007
blocked_h_0008
blocked_h_0009
blocked_h_0010
blocked_h_0011
blocked_h_0012
blocked_h_0013
blocked_h_0014
blocked_h_0015
blocked_h_0016
blocked_h_0017
blocked_h_0018
blocked_h_0019
blocked_h_0020
blocked_h_0021
blocked_h_0022
blocked_h_0023
blocked_h_max
I’m not seeing the parameter that I’ve not entered or the one that should
be entered. Please correct my syntax and this time I’ll be certain to write
it down!
TIA,
Rich
Soeren,
   I wondered about the placement of the separator; it did not look right
where it was yet I did not try moving it to the g.list parameters.
Many thanks,
Rich
