Hi, I have a question. I need to generate a table that says which polygons bordering to each one, for example:
ID1
ID2
1
3
1
2
2
1
2
4
3
1
3
4
3
5
4
2
4
3
4
6
5
3
5
6
6
4
6
5
In this case the polygon 1 borders with the polygons 3 and 2, and so on. How can I do that in Grass?
Thanks in advance for your help
David Montoya González
Ing. Forestal, Universidad Nacional de Colombia
neteler
February 15, 2014, 1:35pm
2
ID1 ID2 1 3 1 2 2 1 2 4 3 1 3 4 3 5
4 2 4 3 4 6 5 3 5 6 6 4 6 5
The module v.to.db offers a "sides" option, perhaps that's useful here.
For an (un)related example, see
http://grasswiki.osgeo.org/wiki/Vector_length_of_common_boundaries
Rather the length you could then just retrieve the IDs.
Hope this points you into the right direction,
ID1 ID2
1 3
1 2
2 1
2 4
3 1
3 4
3 5
4 2
4 3
4 6
5 3
5 6
6 4
6 5
A simple two-liner gets you a csv-file with the neighborhood matrix. Example with the NC-dataset:
v.category boundary_county op=add layer=2 out=counties
v.to.db -p counties op=sides layer=2 qlayer=1 type=boundary > neighbors.csv
This matrix contains the -1 for "no neighbor" and some repetition of pairs. You can use some awk, sort and uniq magic to clean that up:
v.to.db -p counties op=sides layer=2 qlayer=1 type=boundary | awk -F '|' '{if($2!=-1 && $3 !=-1) printf"%i;%i\n", $2,$3}' | sort -n | uniq > neigbhors.csv
Moritz
