Good day all,
I have used v.digit experimentally when digitizing contour lines from a topo map but have a questions about digitizing contour lines, building footprints, and other. The module v.digit has tools for digitizing lines, boundaries and centroids. Contour lines can be open or closed, forming a crude circle, square, etc. When digitizing contour lines that are closed, would you use the line tool and close the contour lines using the snapping tool or would you digitize contour lines similar to this by using the boundary tool? In general, is the boundary tool only used for polygons? What about roads, and buildings? Would you use the line tool, and after apply the snapping tool or would you digitize buildings and roads using the boundary tool? Or does it matter? Does the techniques matter when developing digital elevation models from topo maps?
I also have questions about edge matching using GRASS. I am attempting to digitize and combine two adjacent maps but have not been successful. One way I thought about doing this align the two adjacent maps and tape the two maps together, scan the taped sections, after georeference this portion, cut and possibly use v.patch to combine different map sections. Is there an easier way this could be carried out?
Thanks for any techniques you have to offer.
Charles
