[GRASS-user] Temporal tools on GUI
   Installed here is 7.3.svn, r70787. Several of the tools on the Temporal
menu of the Layer Manager are not working. So far I've tried t.register and
t.info with the same results: the menu display box gains a vertical space in
the center (the pieces align with the Layer Manager and Map Display
windows), then it closes. No dialog box for input is displayed.
   The command line tools work fine.
Rich
On Thu, Mar 23, 2017 at 12:57 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Not sure what you mean, maybe a screenshot would help. Which operating system?
Rich
grass-user mailing list
grass-user@lists.osgeo.org
and
in
tried here with
g.version -g
version=7.3.svn
date=2017
revision=r70792M
build_date=2017-03-23
build_platform=x86_64-w64-mingw32
build_off_t_size=8
every works fine from the Temporal tools on GUI
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Temporal-tools-on-GUI-tp5313905p5314013.html
system?
Anna,
   Slackware-14.1.
   Cannot provide a screen shot as the menu window quickly closes.
   My point is that trying to use t.info and t.register via the GUI does not
work because selecting those items from the Temporal menu is a dead end.
Rich
On Fri, 24 Mar 2017, Helmut Kudrnovsky wrote:
tried here with
g.version -g
version=7.3.svn
date=2017
revision=r70792M
build_off_t_size=8
Hi, Helmut:
   Be that as it may, it does not work here with
GRASS version: 7.3.svn GRASS SVN revision: r70793 Build date: 2017-03-24 Build platform: i686-pc-linux-gnu Platform:
Linux-3.10.104-smp-i686-AMD_Athlon-tm-_II_X2_255_Processor-with-slackware-14.1
Carpe weekend,
Rich
