[GRASS-user] Temporary files in GRASS Script
Greetings all
Following a few questions/emails from Glynn and Antonio regarding GRASS Scripting I have the following question:
What is the main difference between Temporary files creation mentioned in Glynn emails:
**tmp=tmp.myscript.$$**
**And the one used in r.centroid script:**
TMP=$$
TMPFILE=`g.tempfile pid=$TMP`
Thanks
Best regards,
Nikos
Glynn emails:
TMP=$$
The former creates a name with a given format ($$ is the PID of the
shell process running the script).
g.tempfile creates a temporary file at:
  <datbase>/<location>/<mapset>/.tmp/<hostname>/<pid>.<num>
where <num> is chosen such that the name is unique (for g.tempfile, it
will usually be zero; if a process calls G_tempfile() multiple times,
<num> will increment).
Use the former (or something like it) if you want a name for a
temporary map, region, etc. Use the latter if you need a file.
