Hi grass users,
does anybody know how to avoid the temporary use of disk space during execution of r.fill.dir? For large input files it seems that large temporary files are written as well since I got messages like “no disk space left” (running in a minimized environment where not so much disk space is available).
Thanks a lot for any hints…
Christian.
On Wed, Apr 14, 2010 at 11:01 AM, Christian Schwartze
<christian.schwartze@uni-jena.de> wrote:
Hi grass users,
files are written as well since I got messages like "no disk space left"
available).
The command is actually memory demanding. What's the output of
g.region -p
? On how many cells do you work on?
g.region -p says:
projection: 0 (x,y)
zone: 0
north: 6257261.73938969
south: 6124108.23119424
west: 650218.74629604
east: 775529.77427479
nsres: 84.32774427
ewres: 69.6946763
rows: 1579
cols: 1798
cells: 2839042
Hence, working on nearly 3 mill. cells...
Christian.
Sent: Wednesday, April 14, 2010 10:07 PM
To: "Christian Schwartze" <christian.schwartze@uni-jena.de>
Cc: "GRASS user list" <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] temporary maps/space during r.fill.dir execution
Hi grass users,
available).
g.region -p
2010/4/14 Markus Neteler <neteler@osgeo.org>:
available).
btw, is there any particular reason why data are kept in temp files
and then written to raster maps?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Wed, Apr 14, 2010 at 11:33 PM, Martin Landa <landa.martin@gmail.com> wrote:
available).
It gives the advantage to not destroy in --overwrite mode an existing
map when the new attempt fails or was interrupted by the user.
