I have some data from terrestrial laserscanning. We scanned from at least 2 different points. Now I need to put the scanning data together.
Is GRASS able to transform from one xyz to another xyz location?
I have all reference points...
Greetings
Manuel
please visit www.warela.eu
and participate:
WaReLa scientific conference on
Integrated catchment management
for hazard mitigation
September 24-26, 2007 in Trier, Germany
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
together. Is GRASS able to transform from one xyz to another xyz
location? I have all reference points...
how are two do datasets organized? how many points in each?
how is the relation between the two defined? each set have its own
origin of [0,0,0]?
if two sets of less than a million points, with a known distance &
bearing or surveyed positions for the two, and each with its own center
at [0,0,0], you can load them both in with v.in.ascii into the same
mapset, and then move one's coords to the other's using v.transform.
if you can define a more complicatated relationship between the two,
you could use PROJ.4's cs2cs tool, or maybe figure something with
m.proj, v.proj, i.vpoints, or the GUI georect tool, but we'd need more
details about the form of the dataset to give any more advice on those.
