[GRASS-user] test raster or vector
Hi Everybody
a basic question for a shell script in GRASS 6.0.1
In a part of my script, I ask the user to give the name of a map (a vector or a raster)
and I want to test if the user give a raster or a vector.
Do you know how I can proceed to do this test ?
Thanks a lot
Mick
Michaël Rabotin wrote:
Hi Everybody
http://grass.itc.it/grass62/manuals/html62_user/g.parser.html
and
http://grass.itc.it/grass62/source/SUBMITTING_SCRIPTS
for more tips about script writing.
Moritz
Hi Everybody
or a raster)
You can't distunguish between raster and vector by name, they can have
the same name. ???
Maciek
vector or a raster)
first port of call: see the g.parser help page.
  http://grass.ibiblio.org/grass63/manuals/html63_user/g.parser.html
you might want to try
  http://grass.ibiblio.org/grass63/manuals/html63_user/g.findfile.html
  http://grass.ibiblio.org/grass63/manuals/html63_user/g.filename.html
beware the case where there is a raster and a vector of the same name!
(e.g. spearfish dataset)
MAPNAME=roads
#test for raster
g.findfile element=cell file=$MAPNAME
echo $?
0
g.findfile element=cell file=${MAPNAME}2
echo $?
1
#find vector map
g.findfile element=vector file=${MAPNAME}
# example
g.findfile element=cell file=${MAPNAME} > /dev/null
if [ $? -eq 0 ] ; then
  echo "raster [$MAPNAME] exists"
fi
g.findfile element=vector file=${MAPNAME} > /dev/null
  echo "vector [$MAPNAME] exists"
fi
Hamish
Thanks a lot for your responses
In the same way, is it a method to know for a vector map if it is a point, a line or a polygon vector ?
because in a script I’ve to do an overlay but this command doesn’t work for point vector (so I’ve to use v.select) but before to use one of these commands I’ve to know the type of geometry of my vector
Mick
2006/10/26, Hamish < hamish_nospam@yahoo.com>:
vector or a raster)
MAPNAME=roads
#test for raster
echo $?
0
echo $?
1
#find vector map
example
echo “raster [$MAPNAME] exists”
fi
echo “vector [$MAPNAME] exists”
fi
Hamish
point, a
because in a script I've to do an overlay but this command doesn't work for
point vector (so I've to use v.select) but before to use one of these
commands I've to know the type of geometry of my vector
In GRASS you can have different geometries stored in one vector map.
One way to see whether there are points in your vector map is to parse
the v.info output - in GRASS 6.3 CVS Jachym has added a -t flag for a
nicely parsable, terse output.
Maciek
