[GRASS-user] texture instead of color
Hello.
Does any one know if there is a way to get texture areas instead of/or together with a color?
I tried to use psmap, and that work in a way, but it resulted in other problems.
I have also tried qgis with grass plugin, which have good support for different textures, but I could not set a geographical grid in other projections.
Any solutions or ideas?
Martin
In GRASS I think ps.map is your only option.
Perhaps it would be possible to write an addon script to use a
grid of symbols/dots with style or density based on category,
(see v.random.cover script) but there's no real/built-in hatching
possible with the current d.* code AFAIK.
( http://grass.osgeo.org/wiki/AreaFillPatterns#Example_Pattern_files )
what were the other ps.map problems? (I'd like to fix them, or
maybe know a work-around)
In GRASS use the v.mkgrid module to make a grid vector map
bigger than your target area, then use v.proj to pull that into
your plotting projection. Then display this vector's boundary
lines in QGIS. Maybe you have to convert boundaries to lines
first? I'm not sure how much control qgis gives you on that. If
using v.type for that remember you have to use v.category first
to assign cat numbers to the boundary lines, otherwise they'll
be ignored. (I've never been sure if it's been appropriate to
fix that annoyance. maybe with a flag in v.type? ..mmph)
Hamish
