Jaime:
Thanks to you also for the links. I cannot however access them. I would
be really interested in reading them. Could you please send them
as .pdf, that would be great.
The idea of putting examples on Wiki is excellent!
Saludos
Jorge
Am Mittwoch, den 11.07.2007, 17:18 +0200 schrieb
grassuser-request@grass.itc.it:
Send grassuser mailing list submissions to
grassuser@grass.itc.itTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
grassuser-request@grass.itc.itYou can reach the person managing the list at
grassuser-owner@grass.itc.itWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of grassuser digest..."Today's Topics:
1. RE: importing .dgn files in grass (Gerald Nelson)
2. Re: Re: some interesting tools for working with LAS format
(Bernhard Reimar Hoefle)
3. Re: Re: Re: some interesting tools for working with LAS
format (Gerald Nelson)
4. Re: GRASS 6.3 Installation Woes on OS X (William Kyngesburye)
5. Re: thanks to GRASS! (massimo di stefano)
6. Re: thanks to GRASS! (Michael Barton)----------------------------------------------------------------------
Message: 1
Date: Wed, 11 Jul 2007 07:32:46 -0500 (CDT)
Subject: RE: [GRASS-user] importing .dgn files in grass
To: Juan Miguel Garijo <saldinet@yahoo.es>, grassuser
<grassuser@grass.itc.it>
Message-ID: <20070711073246.ASU09993@expms1.cites.uiuc.edu>
Content-Type: text/plain; charset=iso-8859-1This looks like an excellent addition to the Grass FAQ at the grass website. Any chance you could put something there?
Jerry
---- Original message ----
>Date: Wed, 11 Jul 2007 08:04:53 +0200 (CEST)
>From: Juan Miguel Garijo <saldinet@yahoo.es>
>To: grassuser <grassuser@grass.itc.it>
>--- nishith datta <nkdiitd2002@gmail.com> escribi:
>> hi all
>> I have been able to import a dgn file into grass
>> using the v.in.ogr but I
>> have all the point, line and poly
>> features in the same layer. Next When i use v.what
>> then I get a attribute
>> listing which I can't quite understand
>> Anyone who can help me out with - how to seperate
>> the point , lines and
>> polys into three different layers. Also
>> if possible there could be different things
>> represented as lines - roads and
>> rivers both are line features. So how to extract
>> these from the .dgn file
>> into two different layers. I am attaching the output
>> of v.what command for
>> ease of anyone who wishes to help me out.
>> Output of Grass v.what command :-
>> East: -21786.9555969
>> North: -23164.1739966
>> Map: nkd
>> Mapset: PERMANENT
>> Point
>> Layer: 1
>> Category: 9362
>> driver: dbf
>> database:
>> /ramdisk/grass/locations/43p/PERMANENT/dbf/
>> table: nkd
>> key column: cat
>> cat : 9362
>> Type : 17
>> Level : 3
>> GraphicGro : 0
>> ColorIndex : 0
>> Weight : 1
>> Style : 0
>> EntityNum :
>> MSLink :
>> Text : Paswal
>> When I try to see the layers in the .dgn file using
>> the option list
>> available layers in the dataset and exit from
>> v.in.ogr
>> I get the output
>> Data source contains 1 layers:
>> elements
>> But I think the data source contains more than one
>> layer - atleast one line,
>> one point and one poly for sure. What is the meaning
>> of the above
>> output.....
>> Thanks in advance.
>> Nishith
>GRASS Layer, is not the same of dgn's Layer(Level)
>Make a external database conection:
>v.external dsn=yourmap.dgn output=yourmap
>open yourmap in a monitor
>You can test every entity in the dgn with v.what
>Make attention on the Level value, and others fields
>values of the entities you want to include in a vector
>GRASS file.
>Import just this entities with the the option
>"where=":
>v.in.ogr -z -o dsn=yourmap.dgn output=yourmapX
>where=Level=X min_area=0.0001 snap=-1
>And so on for each map
>Juan M. Garijo
>______________________________________________
>LLama Gratis a cualquier PC del Mundo.
>Llamadas a fijos y mviles desde 1 cntimo por minuto.
>http://es.voice.yahoo.com
>_______________________________________________
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801------------------------------
Message: 2
Date: Wed, 11 Jul 2007 15:11:31 +0200
From: Bernhard Reimar Hoefle <Bernhard.Hoefle@uibk.ac.at>
Subject: [GRASS-user] Re: Re: some interesting tools for working with
LAS format
To: grassuser@grass.itc.it
Message-ID: <1184159491.4694d7030587c@web-mail1.uibk.ac.at>
Content-Type: text/plain; charset=ISO-8859-1Hi!
Thanks to Hamish we can now easily convert LAS files to DEMs with r.in.xyz.To remind, LAS Tools can be found here:
http://www.cs.unc.edu/~isenburg/lastools/I successfully compiled and used it like this:
1)
in las2txt.cpp (lastools/tools/src): change main to return int:
int main(int argc, char *argv)2)
g++ ../../src/lasreader.cpp las2txt.cpp -I ../../inc/ -o las2txt
-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=643)
./las2txt test.las -otxt | r.in.xyz input=- output=dtm method=min fs=" "> As a start we can include references to the LAS tools in the relevant man
> pages and wiki, with build and useage examples. This would get new users up
> to speed on the 'toolchain' approach to processing data with GRASS+external
> tools.We should definitely do that.
> While this is always an option, I think that by generalizing things a bit
> further (via a GDAL/ogr driver) or using the LAS tools as a pre-processing
> step would be the best way forward.I absolutely agree with you. But don't know how complicated this implementation
will be and I'm not a programmer, so I cannot really support.Bernhard
Message: 3
Date: Wed, 11 Jul 2007 08:44:06 -0500 (CDT)
Subject: Re: [GRASS-user] Re: Re: some interesting tools for working
with LAS format
To: Bernhard Reimar Hoefle <Bernhard.Hoefle@uibk.ac.at>,
Message-ID: <20070711084406.ASU19174@expms1.cites.uiuc.edu>
Content-Type: text/plain; charset=us-asciiAt a minimum, this description would be good to add to the grass FAQ.
>Subject: [GRASS-user] Re: Re: some interesting tools for working with LAS format
>Hi!
>1)
>2)
>3)
>> tools.
>Bernhard
Gerald Nelson
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Message: 4
Date: Wed, 11 Jul 2007 09:06:52 -0500
Subject: Re: [GRASS-user] GRASS 6.3 Installation Woes on OS X
To: Hamish <hamish_nospam@yahoo.com>
Cc: grassuser@grass.itc.it, uclamathguy@gmail.com
Message-ID: <BD50DBA5-4A3C-4141-9789-87CA954D7CAF@kyngchaos.com>
Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowedOn Jul 11, 2007, at 3:36 AM, Hamish wrote:
> William Kyngesburye wrote:
>> .grass6rc is not something that must exist for GRASS to run. Create
>> it if you need it. I prefer to use .bash_profile instead,
>> since .grass6rc is loaded *after* the initial mapset selection.
> little clarification:
> .grassrc6 holds the GIS variables. It is not a series of shell
> commands.
> It contains things like "DEBUG: 0".
> .grass.bashrc (or .grass.cshrc) contains shell commands to be run at
> initial mapset selection (creation of session shell). It contains
> things
> like "export GRASS_WIDTH=800".
> Maybe .grass6rc exists on your builds for the Mac, I'm not sure,
> but did
> you mean to say .grass.bashrc not .grass6rc?
Right, .grass.bashrc is what I meant. Don't know if that's what Ryan
meant. It's not in the Mac build.-----
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?-HitchHiker's Guide to the Galaxy
Message: 5
Date: Wed, 11 Jul 2007 16:21:19 +0200
Subject: [GRASS-user] Re: thanks to GRASS!
Message-ID: <EBBE78F8-57CF-403E-946C-2B03FD850352@yahoo.it>
Content-Type: text/plain; charset="us-ascii"Hi Jaime,
thanks to grass... and to all the mans that use GFOSS for our rersearch,
as you too
i've not access to scienze direct, but i'm really intersted to this
paper :> Spatio temporal
> analysis of daily precipitation and temperature in the Basin of
> Mexico.please let me know if it is possible to have a copy of it.
my e-mail address is :
massimodisasha@yahoo.it
thanks a ton!
Massimo.
Il giorno 11/lug/07, alle ore 14:29, Jaime Carrera ha scritto:
> Dear list,
> I would just like to thank the GRASS development team for creating
> such a nice piece of software, as without it I couldn't have done
> my PhD work. One of my ideas was to show that Open Source software
> can be used to develop a large project (as some people think that
> free stuff is not good) and the use of GRASS, R, GMT, The GIMP and
> Inkscape was crucial to prove my point.
> If someone is interested in some of this work, please follow these
> links; if someone can't access these links, please let me know and
> I can send a PDF copy of them.
> On the use of GRASS with R and GSTAT to interpolate daily
> climatological variables (rainfall, and both minimum and maximum
> temperature) using different Kriging methods:
> Carrera-Hernandez, J. J. and Gaskin, S.J. (2007). Spatio temporal
> Mexico.
> Journal of Hydrology. DOI: http://dx.doi.org/10.1016/j.jhydrol.
> 2006.12.021
> On the use of GRASS in groundwater modeling (Now I have time to
> update it for GRASS 6.2 and MODFLOW 2005 !)
> Carrera-Hernandez, J. J. and Gaskin, S. J. (2006). The Groundwater
> Modelling Tool for GRASS (GMTG). Open Source groundwater flow
> modelling. Computers & Geosciences 32(3):339-351. DOI: http://
> dx.doi.org/10.1016/j.cageo.2005.06.018
> There is another paper (in press, Hydrogeology Journal) on which I
> used GRASS, R and GMT to analyze the evolution of the groundwater
> level in the Basin of Mexico. The DOI It should be available
> within the next week.
> Cheers,
> Jaime-------------- next part --------------
URL: http://grass.itc.it/pipermail/grassuser/attachments/20070711/66fe8905/attachment-0001.html------------------------------
Message: 6
Date: Wed, 11 Jul 2007 08:16:19 -0700
Subject: Re: [GRASS-user] thanks to GRASS!
To: <grassuser@grass.itc.it>, GRASS devel <grass-dev@grass.itc.it>
Message-ID: <C2BA4253.23D40%michael.barton@asu.edu>
Content-Type: text/plain; charset="iso-8859-1"I wonder if we should start a GRASS "library" on the main site or the WIKI
where users could post PDF's or links to papers on using GRASS?Michael
On 7/11/07 1:03 AM, "Jaime Carrera" <jaicarrerahdez@yahoo.com> wrote:
> Dear list,
> I would just like to thank the GRASS development team for creating such a nice
> piece of software, as without it I couldn't have done my PhD work. One of my
> ideas was to show that Open Source software can be used to develop a large
> project (as some people think that free stuff is not good) and the use of
> GRASS, R, GMT, The GIMP and Inkscape was crucial to prove my point.
> If someone is interested in some of this work, please follow these links; if
> someone can't access these links, please let me know and I can send a PDF copy
> of them.
> On the use of GRASS with R and GSTAT to interpolate daily climatological
> variables (rainfall, and both minimum and maximum temperature) using different
> Kriging methods:
> Carrera-Hernandez, J. J. and Gaskin, S.J. (2007). Spatio temporal analysis of
> daily precipitation and temperature in the Basin of Mexico. Journal of
> Hydrology. DOI: http://dx.doi.org/10.1016/j.jhydrol.2006.12.021
> On the use of GRASS in groundwater modeling (Now I have time to update it for
> Carrera-Hernandez, J. J. and Gaskin, S. J. (2006). The Groundwater Modelling
> Tool for GRASS (GMTG). Open Source groundwater flow modelling. Computers &
> Geosciences 32(3):339-351. DOI: http://dx.doi.org/10.1016/j.cageo.2005.06.018
> There is another paper (in press, Hydrogeology Journal) on which I used GRASS,
> R and GMT to analyze the evolution of the groundwater level in the Basin of
> Mexico. The DOI It should be available within the next week.
> Cheers,
> Jaime
> __________________________________________________
> Correo Yahoo!
> Espacio para todos tus mensajes, antivirus y antispam gratis!
> Regstrate ya - http://correo.espanol.yahoo.com/__________________________________________
Director of Graduate Studies
Arizona State Universityphone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton-------------- next part --------------
URL: http://grass.itc.it/pipermail/grassuser/attachments/20070711/3c9924f5/attachment.html------------------------------
http://grass.itc.it/mailman/listinfo/grassuserEnd of grassuser Digest, Vol 15, Issue 26
Jorge Echeverri, MSc
S & P CONSULT GMBH
Technologiequartier
Konrad-Zuse-Str. 6
D-44801 Bochum, Germany
Geschäftsführer: Dipl.-Ing. Robert Stein
Registergericht: Amtsgericht Bochum HRB 10769
