how do you measure the area of a polygon in grass?
Best Regards
Corrado Topi
Global Climate Change and Biodiversity
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529@york.ac.uk
Best Regards
Corrado Topi
grass-user mailing list
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
1) v.report does not allow for selecting only one polygon in a map with many
polygons.
2) the query button returns the length of the boundary, but not the area.
3) v.to.db does not allow for selecting only one polygon.
Am I doing something wrong?
On Tuesday 11 March 2008 15:07:30 Corrado wrote:
Dear friends,
Best Regards
Best Regards
Corrado Topi
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Environment and Security (US)
If you want to avoid to extract your polygon and then run v.report or
v.to.db on it, I suggest you to use QGIS. When you use "identify", it
gives you the area value too.
Anyway, you can inspect v.report and v.to.db, and look for your polygon cat...
2008/3/11, Corrado <ct529@york.ac.uk>:
Dear friends,
polygons.
> Dear friends,
> Best Regards
Best Regards
Corrado Topi
If you are a bit more careful (given that your vector data are closed
polygons -- check with v.clean) and click inside the polygon it will
report you the area as well. It happened to me as well... but I was not
exactly picking a point inside the polygon and therefore the report was
indicating a boundary and its length.
same with
d.mon x0
d.vect yourmap type=area
d.what.vect
and click on some free space: if you get the boundary or the centroid,
try again.
area for that polygon is reported at the top of the form.
(I assume the same for the GUI query tool, but I'm not sure)
polygon cat...
