[GRASS-user] The export r.out.gdal reduce the resolution of the result from i.fusion.hpf script
Starting on grass 7.0.
I try to use the
i.fusion.hpf script to create a new panchromatic image.
Starting with a raster (from landsat) 30meters and a panchromatic 15meters.
With the i.fusion.hpf I produce a new raster at high resolution (15meters).
The verify that really it has 15m , I open it with the grass display
and measure che legth of the pixel.
Ok, it is really 15meters.
After this I try to export the new raster with the r.gdal.out.
This is the command I run:
(the LC81920302015157LGN00_B4.org_hpf@andrea is the new 15meter raster)
r.out.gdal -f --verbose input=LC81920302015157LGN00_B4.org_hpf@andrea
output=D:\temp\exported_image.tif format=GTiff type=Float64
createopt=INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE
This is the log of execution:
Esportazione al tipo di dato GDAL: Float64
Checking GDAL data type and nodata value...
ERROR 6: SetColorTable() only supported for Byte or UInt16
bands in TIFF format.
Using GDAL data type <Float64>
Input raster map contains cells with NULL-value (no-data). The value
nan will be used to represent no-data values in the input map. You can
specify a nodata value with the nodata option.
Exporting raster data to GTiff format...
WARNING: Too many values, color table cut to 65535 entries
r.out.gdal completo. File <D:\temp\exported_image.tif> created.
I notice the warning for too many values.
But really I don't understand what it mean because this is a float
raster and not an integer raster.
When I go to test the new exported tif image with qgis.
I see the pixel size is now 30meters and not 15meters.
How is possibile that the r.gdal.out could reduce the resolution of the image ?
This is really uncomprensible to me.
Is this a knowed issue ?
Any help is welcome.
Thx.
Andrea Peri
qwerty àèìòù
On Jul 26, 2015 12:05 PM, “Andrea Peri” <aperi2007@gmail.com> wrote:
I try to use the
Checking GDAL data type and nodata value…
Exporting raster data to GTiff format…
But really I don’t understand what it mean because this is a float
Is it possible your computational region is set to 30 m resolution? Try g.region -p. r.out.gdal respects region settings.
Thx.
Andrea Peri
qwerty àèìòù
grass-user mailing list
grass-user@lists.osgeo.org
Hi Anna,
many thx for your reply.
You are right.
The region is set to 30meters.
I was confused from the grass display that show me the pixel cell size
to 15meters.
Thx again.
Andrea.
2015-07-27 7:43 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
On Jul 26, 2015 12:05 PM, "Andrea Peri" <aperi2007@gmail.com> wrote:
I try to use the
15meters.
(15meters).
image ?
Thx.
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
