[GRASS-user] The geotiff format problem
Hi all:
I have exported the roads in the Spanish example DataBase to a geotiff and post it through the wcs.
Then I want to handle it :
1)download the tiff in my webservice.
2)use the geotools to parser the tiff,however I got the errors:GeoKey directory does not exist.
So I wonder the geotiff from the grass is not identified by the geotools?
On Thu, Jul 16, 2009 at 3:10 PM, maven apache<apachemaven0@gmail.com> wrote:
Hi all:
Did you use r.out.gdal? (which GRASS version)?
If yes, then the GDAL library is responsible since GRASS calls GDAL to
generate the file. In that case the gdal-dev list may be of better help.
If no, please tell us how you exported.
2009/7/17 Markus Neteler <neteler@osgeo.org>
Hi all:
Yes, I use the r.out.gdal
I will call the gdal-user list
Thank you!
