Dear all, please give some advice.
The map doesn’t render, but when I move the cursor the coordinates are changing. When I the “set computational regions” I get the
Command ‘d.rast map=ninety@chdet’ failed
The display projection command gives this result
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : tmerc
ellps : grs80
lat_0 : 0
lon_0 : 24
k : 0.9996
x_0 : 500000
y_0 : 0
towgs84 : -199.87,74.79,246.62,0,0,0,0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
and when I choose metadata I get all the information
r.info map=ninety@chdet
| Layer: ninety@chdet Date: Thu Mar 06 17:22:58 2014
| Mapset: chdet Login of Creator: gounaridis.d
| DataBase: H:\GRASSDATA
| Title: ( ninety )
Timestamp: none |
Type of Map: raster Number of Categories: 4 |
Data Type: CELL |
Rows: 584 |
Columns: 632 |
Total Cells: 369088 |
Projection: Transverse Mercator |
N: 4204475.77974522 S: 4186371.77974522 Res: 31 |
E: 502018.59283775 W: 482426.59283775 Res: 31 |
Range of data: min = 1 max = 4 |
Data Description: |
generated by r.in.gdal |
Comments: |
r.in.gdal -o input="D:\mathima1\master\SIGIS\SIGIS\LUCC\DATA\sigisas\ |
k1\cl1990\hdr.adf" output=“ninety” |
System Info
GRASS version: 6.4.3
GRASS SVN Revision:
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.1
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
Thank you for your time
NN
Dear Nikas
Try to run
g.region rast=*_ninety
_*before d.rast. If it does not work, give us the result of
g.region -p
best regards
Juan Carlos Torres
The map doesn't render, but when I move the cursor the coordinates are changing. When I the "set computational regions" I get the
*_Command 'd.rast map=ninety@chdet' failed_*
*g.proj -p*
proj : tmerc
ellps : grs80
lat_0 : 0
lon_0 : 24
k : 0.9996
x_0 : 500000
y_0 : 0
no_defs : defined
unit : metre
units : metres
meters : 1
*r.info <http://r.info> map*=ninety@chdet
| Title: ( ninety )
| Timestamp: none
| Data Type: CELL
| Rows: 584
| Columns: 632
| Total Cells: 369088
| Data Description:
| Comments:
| k1\cl1990\hdr.adf" output="ninety"
*System Info *
GRASS SVN Revision:
GDAL/OGR: 1.10.1
Python: 2.7.5
wxPython: 2.8.12.1
NN
grass-user mailing list
grass-user@lists.osgeo.org
Juan Carlos Torres | http://lsi.ugr.es/~jctorres
Laboratorio de Realidad Virtual | Tlf.: (+34) 645 885 167
Dpto. Lenguajes y Sistemas Informaticos | (+34) 958 249 307
ETS. Ing. Informatica | interno ugr 71 260
Univ. de Granada | FAX: (+34) 958 243 179
