[GRASS-user] the performance of displaying vector attributes
I am facing now with following problem:
I have a large databases of points (more 30 000). I would like to
visualize them in colors according to different attributes using
d.vect.thematc and also store rgb information in the GRASSRGB column. I
noticed that both methods are incredibly slow. It is very frustrating
since you have to zoom and wait ages for refreshing the monitor. My
database is stored using db engine. I would like to ask you if storing
the point database using different engine like postgresql or mysql will
have any impact on the performance in displaying the GRASSRGB column?
I did not tested it yet but I am would like to know if it have any sense
to spent some time on such try?
Is there any other methods to speed-up the display performance in my
case? I would like to add that I checked point displaying on various
hardware combinations and I did not noticed any significant difference.
It is always very slow.
Thanks a lot
Zbigniew
When storing attribute data in MySQL I have found creating an index on
relevant columns had made a large difference.
Dylan
On 11/10/06, Zbigniew Perski <perski@us.edu.pl> wrote:
Thanks a lot
Zbigniew
grassuser mailing list
grassuser@grass.itc.it
Zbigniew Perski napisa³(a):
Thanks a lot
Zbigniew
PgSQL with indexing will increase preformance. unfortunatly I can't say anything about MySQL ....
J.
Hello Zbigniew,
(Cc to Michael and Glynn as they are currently busy reworking
d.vect.thematic)
On Fri, November 10, 2006 17:18, Zbigniew Perski wrote:
There are several performance issues with d.vect.thematic:
1) It is script-based and so if you have lots of points, it might take
longer to calculate classes and colours than a C-based version might
(although I don't know how much difference this would make).
2) Gis.m seems to consider it as a new command everytime you renew the
display in any way leading to all the calculations and rendering having to
be redone. If you have a lot of points, this takes time.
3) I'm not sure the way the database connections are handled in d.vect are
always the most efficient.
4) d.vect in itself is not the most efficient for plotting.
My
As others have said, indexing will probably help you somehwat.
I think the first important element would be to find a way to not rerun
d.vect.thematic at every zoom or refresh...
Moritz
On Sun, 2006-11-12 at 12:33 +0100, Moritz Lennert wrote:
Hello Zbigniew,
d.vect.thematic)
I have couple of suggestions:
1. There is an option to remove outline of the symbols. If you are using
small size (say: 3 to 5)basic/circle the map looks ugly. I propose to
change no outline into outline color = fill color. I have modified in
such way d.vect.thematic and the output looks much better now.
2. Allow full color scale apart from the scaling between two colors. I
created a script which is doing that. It is very slow and I started to
test different approach now: to further modify d.vect.thematic instead
of a script on top of d.vect.thematic (current solution). Since they are
converting it onto C code I will better wait.
If they are interested to look into my solutions please let me know so I
will send you my scripts.
> Hi,
yes. It is not very efficient way.
yes. I was even thinkig to convert all my points to raster layer and
then create kind of pyramid to be able to see my point in different
zooming level
> My
It is crucial.
best regards
Zbigniew
