[GRASS-user] thematic vector map with non-numeric field values
Hello,
how do I disply a thematic map in GRASS for vector attributes that don't have
numeric values?
I tried d.vect.thematic but it would only accept numeric values.
If I have a vector layer with all communities of a country and a attribute
column with the community name and another column with the name of the
corresponding federal state, how do I display for instance a thematic map with
individual values based on the column with the sate names?
I managed to do this on QGIS. But is it also possible in GRASS itself?
Thanks and kind regards,
Tim
numeric values?
with individual values based on the column with the sate names?
not very efficient, but you could use the d.vect where= column to restrict to
e.g. where="state = 'California'". Perhaps write a script with v.db.select or
as Michael suggested add a GRASSRGB column and populate it with db.execute
WHERE state = '...'. Another idea is to dissolve into states with d.dissolve
(by column), then randomly color states with d.vect -c.
Hamish
      ____________________________________________________________________________________
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
Hello,
numeric values?
I'd suggest QGIS. Load a GRASS vector, enter it's
properties, in 'Symbology' tab use 'Legend Type: Unique Value'.
Maciek
numeric values?
Yes, I used that.
But QGis reacts kind of slowly. Therefore, I wanted to do it in GRASS natively.
To my humbly opinion a desktopn GIS should have this feature out-of-the-box. QGIS has it, gvSIG has it. Why is it difficult in GRASS?
The solutions presented above are inflexible workarounds.
Can we have this a wish for the next GRASS version?
Kind regards,
Tim
