Hi folks,
Does anyone know how to do Thiessen Polygons in GRASS?
I need to use them around various types of megalithic tomb sites that are in point vector files.
Thanks for any help you can give.
Kurt
Hi folks,
Kurt
Try
v.surf.idw
Harald
Kurt Springs wrote:
Hi folks,
Kurt
grass-user mailing list
grass-user@lists.osgeo.org
Harald Hofmann PhD Candidate - Hydrogeology School of Geosciences
Bldg 28 Monash University Clayton Campus Wellington Road VIC 3800
Australia
harald.hofmann@sci.monash.edu.au
Office: +61 3 9905 5786
Fax: +61 3 9905 4903
v.voronoi
there is some replacement test code to look at in grass-addons as well:
http://trac.osgeo.org/grass/browser/grass-addons/vector/voronoi
Hamish
That did the trick.
Thanks Hamish
Kurt
sites that are in point vector files.v.voronoi
http://trac.osgeo.org/grass/browser/grass-addons/vector/voronoiHamish
While we are on this topic, is there a way to get a weigthed voronoi diagram using grass ?
The ability to rank a point to tune the area's influence would be great, for that purpose I've been using an arcgis'extension* but with grass it is not possible**. Is there a way to get a similar result ?
*http://www.geog.unt.edu/~pdong/software.htm
**http://osdir.com/ml/gis.grass.user/2004-04/msg00036.html
MORREALE Jean Roc
> v.voronoi
> http://trac.osgeo.org/grass/browser/grass-addons/vector/voronoiWhile we are on this topic, is there a way to get a weigthed voronoi
diagram using grass ?The ability to rank a point to tune the area's influence would be great,
is not possible**. Is there a way to get a similar result ?*http://www.geog.unt.edu/~pdong/software.htm
**http://osdir.com/ml/gis.grass.user/2004-04/msg00036.htmlRegards,
MORREALE Jean Roc
What exactly is a 'weighted voronoi diagram' (the link does not work)? If you
are after a weighted network connecting points, here is one approach:
http://casoilresource.lawr.ucdavis.edu/drupal/node/698
Dylan
Dylan Beaudette
Soil Resource Laboratory
University of California at Davis
530.754.7341
On Wed, Feb 11, 2009 at 5:03 PM, Dylan Beaudette
> v.voronoi
MORREALE Jean Roc
Strike that. Link appears to work and RTFM-ing the user guide...
Dylan
> v.voronoi
MORREALE Jean Roc
Now that I have read about 'weighted voronoi diagrams', I wonder if a
combination of r.cost + r.mapcalc would solve this problem. Something
along those lines is demonstrated here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/288
This example isn't quite what is requested, although using r.cost with
start=point_i, and stop=neighbor_points (derived from v.delaunay /
v.distance?) may work. It would then be a little more work to convert
the weighted-distance rasters into polygons, and link back to the
original attribute tables... but (hopefully) not outside the realm of
possibility via a script.
Dylan
>> > v.voronoi
>> Regards,
>> MORREALE Jean RocNow that I have read about 'weighted voronoi diagrams', I wonder if a
along those lines is demonstrated here:http://casoilresource.lawr.ucdavis.edu/drupal/node/288
The problem with using r.cost is that you would need to know the cost
for each cell before you have created the polygons.
I think that the simplest accurate approach would be to modify
r.grow.distance.
<debeaudette@ucdavis.edu> wrote:On Wednesday 11 February 2009, MORREALE Jean Roc wrote:
One version of such diagrams are Reilly surfaces [1],[2] used in retail geography to identify the influence/attraction zone of a city, often depending on population size.
I wonder if a
This actually raises the same question as [3] about attributing pixels to closest neighbors (where "closest" can obviously be weighted). I think such a functionality would be very useful.
Moritz
[1] Reilly, W.J. (1929) Methods for the study of retail relationships, University of Texas, Bulletin, 2944.
[2] Reilly, W.J. (1931) The law of retail gravitation, New York.
[3] http://lists.osgeo.org/pipermail/grass-user/2009-January/048585.html
While we are on this topic, is there a way to get a weigthed voronoi diagram using grass ? The ability to rank a point to tune the area's influence would be great, for that purpose I've been using an arcgis'extension* but with grass it is not possible**. Is there a way to get a similar result ? *[http://www.geog.unt.edu/~pdong/software.htm](http://www.geog.unt.edu/~pdong/software.htm) **[http://osdir.com/ml/gis.grass.user/2004-04/msg00036.html](http://osdir.com/ml/gis.grass.user/2004-04/msg00036.html) Regards, MORREALE Jean Roc
Now that I have read about 'weighted voronoi diagrams', I wonder if a combination of r.cost + r.mapcalc would solve this problem. Something along those lines is demonstrated here: [http://casoilresource.lawr.ucdavis.edu/drupal/node/288](http://casoilresource.lawr.ucdavis.edu/drupal/node/288) This example isn't quite what is requested, although using r.cost with start=point_i, and stop=neighbor_points (derived from v.delaunay / v.distance?) may work. It would then be a little more work to convert the weighted-distance rasters into polygons, and link back to the original attribute tables... but (hopefully) not outside the realm of possibility via a script.
The problem with using r.cost is that you would need to know the cost for each cell before you have created the polygons. I think that the simplest accurate approach would be to modify r.grow.distance.
Do you mean: adding a metric parameter to Euclidean, Squared, Manhattan, and Maximum? Something like: compute on the basis of the value of traversed cells?
Jan
I didn't knew about it, I'll try look for the reference you gave thank. My aim is quite similar to your example as it consists in balancing the influence zone of a archeological settlement, not by the estimated population, but by a factor resulting from the amount of data collected (historical&material).
MORREALE Jean Roc
The messages from Kurt Spring and Jean Roc Morreale point to archaeological work using GRASS. How many other archaeologists are there on the list using GRASS. I'd be interested in hearing about archaeological applications as I have just begun the learning curve for my own archaeological work.
Lyle Browning
MORREALE Jean Roc
I believe quite a few,
work.
see/add to the GRASS Archeology wiki page linked from:
http://grass.osgeo.org/wiki/Applications
the Archeology page there is still a bit under developed & preliminary,
but as it's a wiki all can help improve it.
regards,
Hamish
> r.grow.distance.Do you mean: adding a metric parameter to Euclidean, Squared, Manhattan,
traversed cells?
I mean scale the distance by the value of the nearest non-null cell.
Yes, I guess that what I meant too, you just formulate it better, in a more general way. I find this interesting, as I have experimented with weighted Voronoi polygons, but only in vector format. There is a complete book on that methodolgy: Atsuyuki Okabe, Barry Boots, Kokochi Sugihara, Sung Nok Chiu: Spatial Tesselations. Concepts and Applications of Voronoi Diagrams. Wiley, Chichester 2000. It’s really fascinating to see how much you can do with this technology, not only in theory but also in practice. Of course, the vector based algorithms are hard to implement and can be very resource hungry. A lot of them are already available however: just Google on “weighted voronoi”. As always, a raster based approach could be not only more efficient, but also conceptually more general. There is an ArcGIS extension available that does exactly this: see http://portal.acm.org/citation.cfm?id=1332465
With that in mind, if the algorithm you propose would be indeed an approximation to weighted Voronoi polygons, and it wouldn’t be all to hard to implement (I have no idea about that), would it make sense to propose this as a new RFC for GRASS?
Jan
approximation to weighted Voronoi polygons, *and* it wouldn't be all to
Oops; I spoke too soon.
In retrospect, this won't work. r.grow.distance relies upon the fact
that once a cell falls out of consideration, it stays out. It will
only consider cells which either are from the current row, or were
used on the previous row.
With distance scaling, this doesn't hold. A cell could be temporarily
overriden by much nearer cells with increased scale factors (lower
weights), then regain its influence once the distance increases.
IOW, this isn't something which can implemented given the algorithm
used by r.grow.distance. Any algorithm which implemented distance
scaling would inevitably have worst-case memory usage proportional to
the number of non-null input cells, as you can never "forget" a cell
whose scale factor is lower than those currently being considered, as
it will eventually regain its influence.
Dear Glynn Clements
Is there a command r.grow.distance on GRASS?
I tryed to find it on Native WinGrass, but it appears not be available, almost on 6.3 version.
Best wishes
miltinho
2009/2/14 Glynn Clements <glynn@gclements.plus.com>
propose this as a new RFC for GRASS?Oops; I spoke too soon.
In retrospect, this won’t work. r.grow.distance relies upon the fact
used on the previous row.With distance scaling, this doesn’t hold. A cell could be temporarily
weights), then regain its influence once the distance increases.IOW, this isn’t something which can implemented given the algorithm
the number of non-null input cells, as you can never “forget” a cell
it will eventually regain its influence.–
It's new in 6.4/7.0.
Jan Hartmann wrote:
With that in mind, if the algorithm you propose would be indeed an approximation to weighted Voronoi polygons, *and* it wouldn't be all to hard to implement (I have no idea about that), would it make sense to propose this as a new RFC for GRASS?
Oops; I spoke too soon. In retrospect, this won't work. r.grow.distance relies upon the fact that once a cell falls out of consideration, it stays out. It will only consider cells which either are from the current row, or were used on the previous row. With distance scaling, this doesn't hold. A cell could be temporarily overriden by much nearer cells with increased scale factors (lower weights), then regain its influence once the distance increases. IOW, this isn't something which can implemented given the algorithm used by r.grow.distance. Any algorithm which implemented distance scaling would inevitably have worst-case memory usage proportional to the number of non-null input cells, as you can never "forget" a cell whose scale factor is lower than those currently being considered, as it will eventually regain its influence.
Do you mean that implementing a raster version of weighted Voronoi methods would be very inefficient, compared to vector methods, or that it would be very difficult? I have tried to see what’s in the ArcGIS extension (http://portal.acm.org/citation.cfm?id=1332465, documentation at: http://www.geog.unt.edu/~pdong/software/VoronoiHelp.pdf), but the math is beyond me. If you think it would be viable to implement this in GRASS, I could have a closer look at it. These weighted Voronoi polygons are really an interesting methodology.
Jan Hartmann
Departmann of Geography
University of Amsterdam
