OS:
OK, I think I shouldn't ask about which OS since foss runs on everything
(right?). But are I am curious to know if there are any advantages using
Debian instead of Ubuntu for example?
Everyone has their own favorite; I've been using Ubuntu and Grass together
since 2004, with no difficulties on 32-bit and 64-bit machines.
Filesystems:
Which filesystem is better(=safer/faster) for data storage? Is there any
important advantage to choose XFS for example rather than ext3?
Not sure about the main differences/advantages of either; I've been using ext3
since forever, with no regrets.
Partitions:
Do you keep your geo-data in a separate partition? I suppose yes. Have
you split further your partition based on other criteria, always related
with "working with geospatial data"?
Pretty much the main 3-4 projects I'm working on are on /home, with anything I
haven't worked on in the last 2-weeks backed up and archived on an external
2TB hardrive. (LaCie)
Do you keep all of your source code in a separate partition maybe?
Nope, just under good old /usr/local. I only compile from scratch those applications where
I need all the bleeding edge goodies and bug fixes, which, for me, is only Grass,
gdal, and lilypond. I try to use the distribution's packages for everything else;
makes it a lot easier to maintain using the package manager than chasing around
and recompiling source for a ton of apps.
Organisation:
GRASS takes care to organise the data inside the GIS data-base and its
fantastic. But what about the "raw" data? How do you organise them?
Manually everything? Any tool to be more productive?
Once raw data is imported into Grass, I usually get it off my hard drive and backed
up onto something external, in case my computer melts down; then I can always
rebuild from scratch. Of course the external drive could also melt down. I guess
a RAID would be even better, but costs more.
BackUp:
How often do you backup your data? Do you just copy or do you compress
as well? What is safer?
I've been using 'tar cjvf' for each project, but that is becoming unmanageable; I need
to migrate to a versioning system as Dylan has done with rsync. At least for the
projects I work on all the time. The old stuff can probably stay on the backup drive
in tar.bz2 format.
Other:
Any other important issues when setting-up a new foss-geo-box?
I just installed Ubuntu Intrepid 8.10 yesterday, and found it much easier
installing packages via Synaptic rather than downloading the bleeding edge
source packages and compiling. The only source package I had to compile was
Grass.
Thank you, Nikos
P.S. Maybe we can add a new wiki-page if something useful comes out of
this thread. Or maybe not...
grass-user mailing list
grass-user@lists.osgeo.org
