[GRASS-user] tips on GRASS Mac users
By the end of this week we will have a new imac as a GIS workstation,
I am familiar with GRASS on linux and windows, but not on a mac. I
know GRASS and QGIS install OK on a mac, so that won't be a problem.
Any other advise/caveats/warning as we do the migrate? We will still
be using our linux machine for GRASS in parallel with mac,
specifically:
1. all GRASS database files should be accessible on both machines, I'm
thinking of using the mac as the GRASS database repo (since it has a
larger Hdd capacity) and have linux read/write access
2. Shell scripts are usable on both machines
3. Remotely access linux machine on the mac
Any ideas?
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
specifically:
Overall, OSX is much like *nix, since it's unix-based.
OSX should have Unix file sharing, but you may have to dig around to configure and enable it. Easiest on the Mac side would be Appleshare (AFP), and I think there is Linux client software for that. Or you could use Windows file sharing on the Mac (it uses Samba), and it would also be available to Windows machines.
Watch out for lots of network activity, though. You probably don't want to write data over the network, lots of temp file usage in GRASS. I'd say symlink common data mapsets to your linux workstation's GRASS data dir, and only do active work directly on the linux ws, then copy to the Mac when done.
mac mount
     grassdb
         location
linux grassdb
     readonly loc -> mac mount/grassdb/location
     working loc
FYI the default shell on OSX is bash. AND, sh IS bash. Other shells are available if you prefer another.
No problems there. I use ssh all the time for shell access between Macs. VNC would be nice for GUI access. OSX Leopard, which you will get on a new Mac, includes a nice builtin VNC client, and there are other free ones available.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
