[GRASS-user] To change DEM resolution
I’ve a DEM with 90m m res. (from CGIAR SRTM) and I need drape over it a map tif (resolution 1m).
Seeing the resultant map in NViz the quality is very low. I suppose it depends from the different resolutions.
There is a way to change the DEM resolution?
Thanks
Regards
Edmondo
On Monday 19 January 2009, Edmondo Elisei wrote:
I've a DEM with 90m m res. (from CGIAR SRTM) and I need drape over it a map
Thanks
Regards
Edmondo
if you are using GRASS64, check out r.resamp.interp, otherwise r.bilinear
should do the trick.
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
