[GRASS-user] to move or not move ? grass64 <- ? -> 7.0
Dear all
I have used grass gis 6.4 and I am happy with this version.
But I was wondering which are the advantages or disadvantages to move
or not grass 7.0
Any thoughts are very welcome.
cheers
Miltinho - mcr@rc.unesp.br
Laboratório de Ecologia Espacial e Conservação - LEEC
Depto de Ecologia - UNESP - Rio Claro
Av. 24A, 1515- Bela Vista
13506-900 Rio Claro, SP, Brasil
Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
Cel: 19 9853-3220 / 19 9853-5430
Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
This can help you to make a decision[1].
[1] http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
On Thu, Jan 10, 2013 at 11:13 PM, Milton Cezar Ribeiro <miltinho.astronauta@gmail.com> wrote:
Dear all
or not grass 7.0
cheers
grass-user mailing list
grass-user@lists.osgeo.org
Rashad
Thanks Rashad,
I understand that grass 7 have a lot of new features (or
improved/fixed ones), including the powerful contribution of python.
But I would like to hear from grass7 users about how stable are this
version. Anyone survive using only grass7 our we need to switch
between them?
By the way, a grass GIS DB/Mapset can be used for both versions ?
Regards
miltinho
2013/1/10, Rashad M <mohammedrashadkm@gmail.com>:
Dear all
or not grass 7.0
cheers
PG ECO & BIODIV
CV
   Rashad
yes you can use grass database across different version. but grass7 needs topolgy rebuilding that can be done easily using v.build.all
On Thu, Jan 10, 2013 at 11:29 PM, Milton Cezar Ribeiro <miltinho.astronauta@gmail.com> wrote:
Thanks Rashad,
between them?
Regards
miltinho
Dear all
or not grass 7.0
cheers
PG ECO & BIODIV
CV
Rashad
Rashad
Hi Milton
I am using GRASS 7.0 most of the time, only switching to 6.4 when I want to use it from QGIS as I don’t manage to get QGIS to work with GRASS 7.0 (that will need some work on the gdal-grass plugin I think). Switching is no problem, it requires rebuilding the topology from one to the other version, but that is easy and quick.
It is a development version, so you always run the risk something get’s broken. To minimize the risk, I am always keeping a backup of the latest build that worked well so I can always switch back to that build if something is not working after an update.
All in all, it has been very stable for me, with only a few issues after updates. These were always solved quickly and I never had to revert to a previous build. Your luck may vary of course, also depending on your operating system (I am working on Ubuntu), so I would recommend running the two version, trying out how it works for you.
Paulo
On Thu, Jan 10, 2013 at 6:59 PM, Milton Cezar Ribeiro <miltinho.astronauta@gmail.com> wrote:
Thanks Rashad,
between them?
Regards
miltinho
Dear all
or not grass 7.0
cheers
PG ECO & BIODIV
CV
Rashad
On Thu, Jan 10, 2013 at 03:59:49PM -0200, Milton Cezar Ribeiro wrote:
Thanks Rashad,
between them?
I have seen quite a bit of bugs in grass 7, but the GRASS developpers
are very quick to fix a correctly reported bug.
Pat
Thanks Rashad,
between them?
Some of the bugs reported by you were really helpful to improve new
functionality in GRASS 7. GRASS developers actually depend on this
kind of feedback, and the more power-users use GRASS 7 and report any
bugs, the better. In general, I estimate that GRASS 7 (on the command
line) is as robust, but if in doubt faster and less resource intensive
than GRASS 6.
Some of the bugs reported by you apply to GRASS 6 only, are fixed in
GRASS 7 and can not be backported to GRASS 6 because the required
changes would break GRASS 6 compatibility.
Other bugs that were present in GRASS 6 + 7 are only fixed in GRASS 7
and may or may not be backported to GRASS 6.
Obviously I am advocating the use of GRASS 7, but for production work
I would, like Paolo, recommend to have GRASS 6 on the side.
As a GRASS developer, I personally use only GRASS 7 for production work.
Markus M
I also use GRASS 7 all the time,
2 years ago I was still in need of GRASS 6 on the side,
Now I have not used it in a good year.
Note: I am using GRASS 7 from the SVN trunk, so I get bug fixes daily.
Il 10/01/2013 19:56, Paulo van Breugel ha scritto:
Hi Milton
from QGIS as I don't manage to get QGIS to work with GRASS 7.0 (that will need some
I do not think it is much work to update the plugin to use grass7; it would be a nice
addition: any volunteer or supporter?
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thanks Rashad,
I understand that grass 7 have a lot of new features (or improved/fixed ones), including
the powerful contribution of python. But I would like to hear from grass7 users about how
stable are this version. Anyone survive using only grass7 our we need to switch between
them?
I have seen quite a bit of bugs in grass 7, but the GRASS developpers are very quick to fix a
Some of the bugs reported by you were really helpful to improve new functionality in GRASS 7.
GRASS developers actually depend on this kind of feedback, and the more power-users use GRASS 7
and report any bugs, the better. In general, I estimate that GRASS 7 (on the command line) is
as robust, but if in doubt faster and less resource intensive than GRASS 6.
Some of the bugs reported by you apply to GRASS 6 only, are fixed in GRASS 7 and can not be
backported to GRASS 6 because the required changes would break GRASS 6 compatibility.
Other bugs that were present in GRASS 6 + 7 are only fixed in GRASS 7 and may or may not be
Obviously I am advocating the use of GRASS 7, but for production work I would, like Paolo,
Following the discussion, I would like to install GRASS 7 weekly snapshot. I relized the "Binary"
link (http://grass.osgeo.org/download/software/) but it points back to the Linux Download page,
but I could not find any binaries there for GRASS 7? Maybe this link should be removed?
Just wondering, but not a problem, as I am going to install from source anyway.
Rainer
Markus M _______________________________________________ grass-user mailing list
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iEYEARECAAYFAlDv0x0ACgkQoYgNqgF2egoqQwCfdumTTn6cTYJnqY7x3+FG3Nh5
WSsAmgK0Zla/k50jR7ACYigTA1fZhcv7
=GMNE
-----END PGP SIGNATURE-----
Hash: SHA1
Thanks Rashad,
them?
The binaries are here
http://grass.osgeo.org/grass64/binary/linux/snapshot/
http://grass.osgeo.org/grass65/binary/linux/snapshot/
http://grass.osgeo.org/grass70/binary/linux/snapshot/
The corresponding links should be updated.
Markus M
Rainer
=GMNE
Hello,
as a (not so active) GRASS developer, I also use 7 for almost all my
daily needs. I agree about all nice things of using 7 previously
stated, still I also must give a fat warning - some code in 7 is not
yet tested enough. There are new bugs present in 7 only too.
Here is (infamous) example of it - output result is shifted by n
cells.[1] Issue was present only in 7 in not so well tested new code.
Bugs do happen and GRASS 7 contains new bugs yet unknown. Anyone is
welcome to use GRASS 7, but remember to check outputs and be ready to
report back issues.
Maris.
1. https://trac.osgeo.org/grass/changeset/53889
2013/1/10 Markus Metz <markus.metz.giswork@gmail.com>:
Thanks Rashad,
between them?
than GRASS 6.
Markus M
Hash: SHA1
On 11/01/13 10:41, Markus Metz wrote:
On Fri, Jan 11, 2013 at 9:53 AM, Rainer M Krug <r.m.krug@gmail.com> wrote: On 10/01/13 22:28,
Thanks Rashad,
including the powerful contribution of python. But I would like to hear from grass7
users about how stable are this version. Anyone survive using only grass7 our we
need to switch between them?
GRASS 7. GRASS developers actually depend on this kind of feedback, and the more
power-users use GRASS 7 and report any bugs, the better. In general, I estimate that
GRASS 7 (on the command line) is as robust, but if in doubt faster and less resource
be backported to GRASS 6 because the required changes would break GRASS 6 compatibility.
"Binary" link (http://grass.osgeo.org/download/software/) but it points back to the Linux
Download page, but I could not find any binaries there for GRASS 7? Maybe this link should be
removed?
Rainer
Markus M
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
iEYEARECAAYFAlDv49QACgkQoYgNqgF2egrMtgCfbyWiILrtGy6aSbY9DpTVHO8j
S/oAnioZwYaIVpW17dFwb2tCAslgC3d5
=jUVu
Milton Cezar Ribeiro:
or not grass 7.0
I use both, grass64 and grass70 -- still, for production I am attached to
grass64. I use(d) grass70 for some tasks which, indeed run faster (one recent
example was v.to.rast -- while it did not complete on grass64, it did so in
grass70).
Seeing so many positive feebacks concerning grass70, I'll switch probably soon
to it. I have, however, one concern:
is it possible to "revert" a grass70 vector back to a grass64 vector, just in
case this is required, for whatsoever may be the reason?
Thank you, Nikos
Hi NIkos,
in case this is required, for whatsoever may be the reason?
you need to build the vector topology again, using grass64...
I did not see any other drawback...
Best regards
Pietro
Nikos:
Pietro:
Thanks Pietro I think I have tried that in the past. Now, I was not sure it's
doable.
Nikos
In the past days I have cleaned up several of the Web pages.
I hope they are much clearer now. GRASS 7 downloads are now properly
mentioned as well.
Feedback welcome,
PS: sorry for the delay (due to my hospital stay)
